It is currently Thu Oct 29, 2026 7:11 pm
Vehicle: Turboed 96 Softtop Vitara
Post Posted: Tue Aug 23, 2016 3:02 pm
Found this the might interest a few people that are looking in to changing ECU for forced induction etc
1) ECU patch lead. Link below is for a lead that depending on plugs used matches Vitara EFI ECUs ( both 2 and 3 plug). Ie if you have the 2 yellow plug ecu like myself you use plug 1 and 4.
https://www.amazon.com/gp/product/B0028ZOXYE/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
2) ECU reader tool that works on pre OBD2 ECUs
http://www.rhinopower.org/diag/sdl_if.html
Vehicle: Suzuki Sierra Sj80
Post Posted: Wed Sep 28, 2016 9:57 pm
Have you purchased one of the obd scan tools?
What exactly are the bennifits of having one of these ?
Sorry for the noobie question,
Post Posted: Mon Oct 10, 2016 8:15 pm
Hey, just wondering what this would be used for ?
Sorry I'm new to the whole computer in the car thing.
Thanks
Post Posted: Sun Oct 16, 2016 1:11 pm
No Problem.
Yes I have a purchased a rhynopower scan tool set up.
Its used to obtain data from the factory ECU so you know how your piggyback is effecting the system and that your changes are in balance (i.e. remove volts from 02 signal and Add fuel to injector pulse) are balanced so the stock ecu see nothing.
this allows you to see fuel trends, temps, rap speed, MAF timing etc basically everything the ECU receives from sensors and sends to control things
IT also shows stored codes, current codes, can text ICV. cel and fuel ECU resets.
Thanks
No i did not purchase, i cut into my factory loom already to install my piggyback, (I found this after installing mine :( )
The advantage of this if if you are either going for a piggyback or standalone ECU you do not have to butcher your factory wiring loom. You just use the connections and wires needed and make a adapter/ patch lead
Stand alone - plugs that match the factory ecu 1 end and halted/ motel / etc on the other.
Piggyback - just plug in-between factory look and ECU so when tapping and intercepting the signal ware you only but into this patch lead.
Advantage is that if you have to go back to stock you have not modified your factory loom.
