| Anti Wrap Bar http://auszookers.com/forum/viewtopic.php?f=14&t=5454 |
| Author: | Munster [ Sun Jul 05, 2009 1:59 pm ] |
| Post subject: | Anti Wrap Bar |
This is my attempt at making an anti wrap bar for my Zook.
I used two lower control arms from a Nissan Patrol and cut one to weld to the other. The plates were cut to fit the diff and weld to it. I will be fitting this when my new spring perches arrive from Locktup. I have some more fabrication ahead to fit the bar to the crossmember and also make a slide and twist connection in the bar. I will upgrade this post as I progress. |
| Author: | 11_evl [ Sun Jul 05, 2009 4:56 pm ] |
| Post subject: | Re: Anti Wrap Bar |
looks good but you will have to make more brackets to spread the load on the diff. it will break if you just weld on like that. |
| Author: | Munster [ Sun Jul 05, 2009 8:00 pm ] |
I will be welding more brackets to the back as well. |
| Author: | atari4x4 [ Sun Jul 05, 2009 9:37 pm ] |
i bent those trailing arms on a pootrol like they were made of spaghetti..... |
| Author: | Brett [ Sun Jul 05, 2009 11:55 pm ] |
you need some ting to let the diff move in a ark. it doesn't move straight up and down, it has a ark in the travel |
| Author: | 31zook [ Sun Jul 05, 2009 11:56 pm ] |
Brett wrote: you need some ting to let the diff move in a ark. it doesn't move straight up and down, it has a ark in the travel
X2 |
| Author: | Munster [ Mon Jul 06, 2009 12:29 am ] |
I will be putting a slip & twist section in it. There is still a lot to do to it. |
| Author: | dank [ Mon Jul 06, 2009 12:38 am ] |
check out joeblows anti wrap bar on Kenn's blue LJ. He only has a standard bush on the chassis end. WHen you think about it a standard/modified diff/suspension setup if wrap bar mounted in centre of diff isn't really going to rotate much more than 15-20 degrees which a standard nissan bush shouldn't have too many issues with. If you are getting more than that out of standard leaves then you are doing well especially with zook diffs. Looks good munster...interested to see your chassis setup. |
| Author: | brendan [ Mon Jul 06, 2009 12:49 am ] |
i would be interested in how it works mounted on the bodymount crossmember, if that where your mounting it. just would like to know how i goe on that sor of angle |
| Author: | Munster [ Mon Jul 06, 2009 11:58 pm ] |
I will be mounting it on the crossmember but strengthening it. |
| Author: | joeblow [ Tue Jul 07, 2009 12:32 am ] |
Munster wrote: i WILL BE MOUNTING IT ON THE CROSSMEMBER BUT WILL BE STRENGTHENING IT SOMEWHAT.
STOP SHOUTING........
| Author: | Munster [ Tue Jul 14, 2009 12:49 pm ] |
My question is should the wrap bar be positioned horizontally in the centre of the diff, my feeling is that it should to allow for flexing from side to side? |
| Author: | Munster [ Tue Sep 22, 2009 12:17 pm ] |
I've finished my bar finally -
So far on the road it works great, no axle wrap, but in the bush will be the ultimate test. |
| Author: | Munster [ Wed Sep 30, 2009 5:11 pm ] |
Had a drive last Sunday, the bar worked great and I am very pleased with the result. Absolutely no axle wrap. |
| Author: | brendan [ Fri Oct 02, 2009 2:20 am ] |
looks a bit like mine. and dont post up you went to menai |
| Author: | Scrawny [ Fri Oct 02, 2009 2:04 pm ] |
There's a bit of a pinion seal leak too |
| Author: | Munster [ Fri Oct 02, 2009 2:11 pm ] |
I am going to fit a new pinion seal this weekend. |
