It is currently Sun Oct 25, 2026 2:43 am
Post Posted: Sun Sep 13, 2009 7:14 am
i have used this kind of set up before and always had good results, using a fuse block from an VP commodore i picked up from U-Pullit the local pic a part. i knocked up a little bracket to pick up a captive nut used by the washer bottle & using the original fuse block mount. next will be brackets for relays and final wiring for accessories.
the fuse block has a main feed which is fused @ 60amp then there are 4 outputs that can be fused from 10amp up to 40amp and a spot for a spare fuse
space
fuse block
bracketomerty
mounted
dummied it up with relays i had to see how it will all sit together.
rear of fuse block
relays and looms
switches
i've been running this set up for the last 3years & it's never failed
Post Posted: Sun Sep 13, 2009 10:48 am
That's really neat. Who'd have thought a VP Shitadore would be that useful!
Post Posted: Sun Sep 13, 2009 11:32 am
you can buy that block pretty cheap from holden too, along with the proper crimp plugs ans so on :)
they also have a good relay block under the dash :)
Users browsing this forum: No registered users and 19 guests
