http://auszookers.com/forum/
Dual Battery Install
http://auszookers.com/forum/viewtopic.php?f=14&t=9899
Author:  mike.knew [ Mon Feb 15, 2010 11:12 pm ]
Post subject:  Dual Battery Install
Hi Zookers,
I have been wanting to do a dual battery setup for quiet a while now as I am going on a trip around Tassie next month and I have been able to borrow a fridge.
After heaps of head scratching I just couldn't seem to fit a deep cycle battery battery under the bonnet so I decide to fit a battery box in the back on top of my drawers but after I mounted the battery in I just wasn't happy. The battery was large, heavy (just under 25Kg), took up valuable space, high center of gravity and I wasn't happy with a normal type of battery venting into the car so back to the drawing board:
So after reading through some old 4WD magazines on a fridge comparison I though I could get away with a 55AH battery, and if I got a glass pack type I wouldn't have to worry abut the battery venting into the car and I could mount it on the side so here we go:
Dual battery kit
has a 12.8 cut in voltage and a 12.7 cut out voltage.
From the off cuts left over from the drawers I cut a piece that would fit under the seat so I could use this piece to hold onto the sides of the battery and also reuse the same mount holes as the jack handle:
This is the sort of space I have to play with, the battery needed to be far enough back to not hit the cable that connects the two slide latches for the rails:
Then cut a hole for the battery to sit in:
Then ran some cable from the main battery to the drivers side, through a grommet in the firewall, under the dash and down the center console.
I spent hours trying to get the cable through on the passenger side but I just couldn't get it - it was like the snake/rope was going into the ducting for the vents?
Then i made a bracket that would hold the battery isolator and screw onto a screw/bolt near the gear selector:
Made a bracket to mount on the top so the battery doesn't bounce out:
and job done ... well almost:
I still would like to put a fuse on each battery so all cabling is protected between the two. You can get inline fuses for car stereos that have a 60A fuse so I think that would do the trick, I also need to run some auxiliary circuits from the second battery so next weekend :)
Author:  mike.knew [ Mon Feb 15, 2010 11:20 pm ]
Post subject:  Re: Dual Battery Install
I also went to Bunnings and got a length of 100mm down pipe and some screw on ends. A 3 meter length was the same price as a 1 meter length from off the shelf - figure that one out, I needed a 1.5 meter length so I got them to cut to fit. $40 all up.
Glue the ends on:
A bit of a trail fit using some cable ties:
I had to file bit of a channel into the pipe so they mounted better on the racks, I want to get a bit more of a wear mark in and I will make it deeper.
another picture:
I am thinking of getting more, larger cable ties as they seem to be doing a good job or I may use large hose type clamps. Not 100% in this area.
Enjoy 8)
Author:  Gonzo [ Mon Feb 15, 2010 11:50 pm ]
Nice photo's mate !
Did you have someone taking photo's for you ?
I would get the shits if I stoped and took photo's all the time, Lol
Author:  brendan [ Tue Feb 16, 2010 12:32 am ]
i dont realy what the timber is for but anyway, good idea. you sure you can mount them batterys on there side?
Author:  steak_knife [ Tue Feb 16, 2010 12:45 am ]
I was under the impression that a battery can only be mounted it a HIGH ventilation area, i.e, NOT in the cabin unless in a sealed containment & ventilation's made to suit.
Author:  Sutho [ Tue Feb 16, 2010 1:29 am ]
your mad we charge like 40 bucks for a 6m length at Reece
Author:  pyrohamish [ Tue Feb 16, 2010 1:33 am ]
I don't think they do need ventilation being a fully sealed battery from what I could see?
How much did you pay for the dual battery kit, realised I sell the same relays where I work in a boat chandlery.
Author:  want33s [ Tue Feb 16, 2010 1:55 am ]
AGM batteries are sealed hence need NO ventilation and can be positioned in any plane... IE: on their side or end or even upside down if need be.
They are also legally allowed to be placed in a passenger compartment as used in cars like R31-32-33 Skylines where the battery is under the back seat..
Author:  mike.knew [ Tue Feb 16, 2010 1:59 am ]
Gonzo wrote:
Nice photo's mate !
It only takes a click. Its pulling my finger out and doing a post is what that slows me down. Plus I like reading other people build threads so happy to contribute.
The timber is to stop the battery moving backwards and forwards plus I can use the existing holes in the floor, no extra ones. I don't like drilling any holes in my car unless it can be avoided.
Is that in reference to legality or battery operation? It is a sealed battery (glass packed, similar to a gel cell) so I thought on its side and under the seat shouldn't be an issue.
$40 is including the end caps. $20 for a 3m length.
$249 is RRP for the dual battery kit. I didn't pay anything like that, my girlfriends brother manages a battery shop so I saved mega dollars. It just goes to show the mega price hike retail stores put on.
Author:  atari4x4 [ Tue Feb 16, 2010 2:11 am ]
top effort mike, very neat install... i'll be doing something similar one day. i like the use of the space under the seat!!
nice choice in roof basket 8)
Author:  atari4x4 [ Tue Feb 16, 2010 2:14 am ]
Gonzo wrote:
Nice photo's mate !
if it wasn't for people adding photo's the forums would be a boring place full of words... & we like photos here. :finger:
it's not that hard to take a photo along the way & it's a great way to contribute back to the forum we all love & use. :roll:
Author:  mike.knew [ Tue Feb 16, 2010 2:21 am ]
G'day Atari. I am very happy with it and I reckon it is the way to go, nice and low for your center of gravity too. I even looked at moving the air compressor but I still don't think you could fit a battery there.
Well picked up .... all the cool kids on the block have rola roof baskets 8)
I might have a crack and see if I can get something like these:
Rhino Rack - Conduit pipe clamp set
to fit onto the rack
Author:  atari4x4 [ Tue Feb 16, 2010 2:30 am ]
cable ties are the future... 8O
does the battery board pick up the holes for the jack handle?
Author:  mike.knew [ Tue Feb 16, 2010 3:04 am ]
Yep spot on. That way no extra holes needed to be drilled in the car.
I didn't have a photo for underneath the board but I used what I think are called carriage bolts
Author:  Muzza [ Tue Feb 16, 2010 4:44 am ]
Nice Pics, looks like a good job to me. Looking at you interior makes mine look like a Dinosuar. Nice Job Mate.
Author:  royce [ Tue Feb 16, 2010 12:49 pm ]
Thats a pretty good use of some normally wasted space in a vit, I have an AGM here I have thought about putting under the seat for the stereo but 3 batteries is starting to get silly :)
that wood will give a good base to stick a nice fuse panel on as well, I can recommend something from a boat shop or look at the fusible link block from a commodore like Atari did or look in VR-VS Commodores for the relay block under the bonnet, it has mounts for relays and a nice little 3 fuse block thats all modular so you can swap em to suit what you need, the panel under the dash is pretty useful too
Author:  atari4x4 [ Wed Feb 17, 2010 3:49 am ]
who would have thought that a crumpledoor would be so useful :wink:
Author:  royce [ Wed Feb 17, 2010 12:31 pm ]
I tell you what its a good feeling slicing a whole heap of them out knowing that cause of they they will never run again :)
Author:  pyrohamish [ Wed Feb 17, 2010 10:39 pm ]
Think at work we just sell the relay piece, for around $130, not sure though not working for a week or so so cant check
