| Author |
Message |
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Tue Mar 01, 2011 4:38 am |
It's pretty straight forward but I thought I'd post it up for reference. I hope it'll help someone.
Note: The tyre does not have to be taken off the car. If the sidewall is punctured, It is reccomended that you have it replaced. The self vulcanising kit is only a temporary repair, the tyre should be take to a tyre shop to be repaired properly.
I am using the ARB Tyre repair kit.
Remove what punctured it, In this case a screw.
Use the lube supplied and smear a bit on the reamer tool.
push and turn the reamer tool to clean any debris
With the reamer tool still inserted, inflate the tyre.
Thread the repair cord through the eye of the insertion tool, make sure each length is equal.
Lube the tip and insert all the way in.
Hold the collar down whilst pulling the handle straight up. Do not twist.
Trim off any excess
Fatzook
 Posted: Tue Mar 01, 2011 4:46 am |
Nice write up.
Do you realise that in 30% of those photos your are flipping something off?
buzbox
 Posted: Tue Mar 01, 2011 4:50 am |
Hand modeling auszooker's style.
atari4x4
 Posted: Tue Mar 01, 2011 5:11 am |
 nice work on the NT salutes, oh & good work on the write up.
Hotshot993
Joined: Wed Dec 01, 2010 9:46 pm Posts: 1270 Location: Brisbane
 Posted: Tue Mar 01, 2011 5:14 am |
i dont get one bit. you inflate with the reamer tool in, why do you do that? dont you pull it straight back out anyway to insert the repair cord?
royce
 Posted: Tue Mar 01, 2011 5:20 am |
Hotshot993 wrote: i dont get one bit. you inflate with the reamer tool in, why do you do that? dont you pull it straight back out anyway to insert the repair cord?
The chord is pretty hard work to get in, having the tyre pumped up stops the tread from pushing in when you push on it, much easier to work with
You dont lose alot of air when you pull the reamer out, if you are quick
buzbox
 Posted: Tue Mar 01, 2011 5:21 am |
I don't think it's really necessary but inflating the tyre will help to insert the cord and remove the tool because it the tyre will be harder.
When your using a propper air compressor like i did, you shouldn't have to plug the hole, but if your out in the bush relying on your tyre inflator, If you try to inflate it with the hole not covered up, well the air may escape quicker that your inflating it. So keep the reamer tip still in the hole and remove it when your ready to put the cord through.
Hotshot993
 Posted: Tue Mar 01, 2011 5:27 am |
oh okay thanks. that makes sense. is that a good kit your got in the photos, how many repairs can you get out of it? and also how much did it cost.
thanks for the help royce and buzbox
royce
 Posted: Tue Mar 01, 2011 5:32 am |
Back when I was your age hotty I used to work in a servo on Sundays and part of what I had to do was plug up tyres with one of them kits (was legal back then)
Using a Speedy Seal kit (looks the same) I would of done easilly a few hundred of em, worst that would happen is the reamer snaps if you get too excited.
when you run out of ropes you can buy more in packs of 10, same with the lube
Hotshot993
 Posted: Tue Mar 01, 2011 5:34 am |
buzbox
 Posted: Tue Mar 01, 2011 5:49 am |
The ARB Speedy seal kit usuallt costs $60
This kit comes with 25 plugs, and obviously you can buy more from most car shops. It also comes with a valve accesory kit which includes new valve cores, valve repair and remover tool, fancy "chromies" and plastic valve covers.
It is a good quality kit and fits nicely and comfortably in my paws, You don't need too much force to use it but stay away from the cheaper plastic handle type, The handle may snap or the probe may come apart from the handle. Although if it get's you out of trouble, it's paid itself off. I keep this kit in my recovery bag and in the 2 years of owning it I've never had to use it, until now.
Hotshot993
 Posted: Tue Mar 01, 2011 5:53 am |
Oh okay. On ARB site it doesn't say how much it cost.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Mar 01, 2011 6:05 am |
why wasn't this thread here 6 months ago when i needed to plug a tyre.
i plugged a 33x12.5 tyre on a troopcarrier and put 20psi in it and i just checked it and it has 19psi.
great way to fix a tyre.
http://auszookers.com/index.php?name=Fo ... re&start=0
i ended up buying the kit that kirstyandgrace suggested and while i haven't used it on anything it looks the goods
ooppss nearly forgot
:stekky:
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
turbo_deo
Joined: Mon Oct 11, 2010 5:14 am Posts: 542 Location: Newcastle
Vehicle: Work van
 Posted: Tue Mar 01, 2011 6:08 am |
royce wrote: Back when I was your age hotty I used to work in a servo on Sundays and part of what I had to do was plug up tyres with one of them kits (was legal back then)
Do you know the reason why they are not legal anymore? Curiosity that's all
_________________ Swb softie spoa cromo front -50 beadlocks 6.5s
Fatzook
 Posted: Tue Mar 01, 2011 6:22 am |
I think the preffered method is an internal patch with vulcanising glue.
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Tue Mar 01, 2011 6:24 am |
buzbox
 Posted: Tue Mar 01, 2011 6:31 am |
shep wrote: why wasn't this thread here 6 months ago when i needed to plug a tyre.
Because I didn't have to use it 6 months ago
There's alot of chit chat in that thread but to do it properly it should be repaired with a mushroom plug. With some tyre specific glue these plugs actually vulcanise the rubber whereas the others dont.
royce
 Posted: Tue Mar 01, 2011 7:35 am |
turbo_deo wrote: royce wrote: Back when I was your age hotty I used to work in a servo on Sundays and part of what I had to do was plug up tyres with one of them kits (was legal back then)
when you run out of ropes you can buy more in packs of 10, same with the lube Do you know the reason why they are not legal anymore? Curiosity that's all
you arent likely to dismount the tyre and inspect inside for damage to teh belts with one of those, also there is talk that they will weep and allow moisture into the belt which will rust
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Tue Mar 01, 2011 8:14 am |
Fatzook wrote: I think the preffered method is an internal patch with vulcanising glue.
Pretty sure the "lube" is also vulcanising cement.
:stekky: :stekky:
_________________ Watch out or you'll get sued.
Fatzook
 Posted: Tue Mar 01, 2011 8:21 am |
stockman wrote: Fatzook wrote: I think the preffered method is an internal patch with vulcanising glue. Pretty sure the "lube" is also vulcanising cement. :stekky: :stekky:
who mentioned lube?
S13RR4
Joined: Sat Aug 22, 2009 11:30 pm Posts: 1072 Location: Sunshine Coast
 Posted: Tue Mar 01, 2011 8:35 am |
When I was doing puncture repairs on car tyres it was usually just a patch (like a bike tyre one but betterer) for most small holes, if the hole was bigger then we would drill it out and use the 't' shape plugs posted above.
_________________ My Rig --> Click WWW
BlueSuzy
 Posted: Mon Mar 07, 2011 11:22 pm |
Supercheap have a kit also, plastic handles. Fits easily in my compressor case.
