It is currently Sat Oct 17, 2026 9:17 am
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3
Post Posted: Thu Apr 07, 2011 9:40 am
Fity wrote:
Post some close up pics of the chassie and gearbox mounted in your LJ81 chassie and maybe we can brain fart together. :) Any tips on where to find a Super Carry gearbox?
I can't at the moment, the gearbox is wrapped up and put away, and the chassis is upside down ready for spring bracket modification.
The best solution I see is to cut out the middle section of the crossmember between the 2 uprights, and run some sort of new brace down lower. This will allow me to lower the gearbox then make up some sort of angle brackets to fix it to the uprights. My issue is the cutting up the crossmember bit....
I also have to make an adapter for the shifter mechanism and shorten and change a flange on a jackshaft, and motivation is lacking at the moment...
I found my gearbox on here, someone was selling it. Haven't seen a single other one for sale anywhere.... :?
Clearance Hole Technology :P
Users browsing this forum: No registered users and 10 guests
