| Author |
Message |
MikeyS
Joined: Mon Jan 14, 2013 10:24 am Posts: 202 Location: QLD
Vehicle: 98 Jimny
 Posted: Mon Jun 23, 2014 8:42 pm |
my speedo isn't working anymore  Did anyone work out what causes this to happen??
atari4x4
 Posted: Mon Jun 23, 2014 8:55 pm |
my guess would be it's most likely the spacing between the speedo cog & the sensor.
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Mon Jun 23, 2014 9:06 pm |
Do you have the old kit with enclosed speedo adapter or the newer open style?
Checked the wiring?
Mine has never stopped working but that could have something to do with my dislike of mud.
_________________ Click WWW below for STICKERS
MikeyS
Vehicle: 98 Jimny
 Posted: Thu Jun 26, 2014 10:03 pm |
i have the new one. i think the nuts bolts on the flange have hit the sensor, there is plastic on a couple of ends of the bolts soo sadly thats what i get for doing the conversion at late times of the night  there is a small bit of plastic missing of the side facing the bolts must of been enough to break the sensor
MikeyS
Vehicle: 98 Jimny
 Posted: Thu Jun 26, 2014 10:20 pm |
 Broken sensor i guess
atari4x4
 Posted: Thu Jun 26, 2014 10:23 pm |
look how long your bolts are... those 2 were always going to try & make babies.
zukenutter
 Posted: Fri Jun 27, 2014 7:03 am |
Sounds like you found your problem. On a side note, the new kit seems to position the sensor quite off line from the ring. Looks to be all in the right positions but strange that they haven't positioned it a bit closer to the transfer.
MikeyS
Vehicle: 98 Jimny
 Posted: Fri Jun 27, 2014 9:56 pm |
i did it really late at night/early in the morning hoping to be done for cruiser park that morning
cal213
Joined: Fri Oct 12, 2012 9:01 pm Posts: 308 Location: traralgon vic
Vehicle: jimny g13bb, 99 wrx!
 Posted: Wed Jul 23, 2014 6:40 pm |
Any word on the speedo fix? Just done my install and i also have no speedo!!!
Blkfxx
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
 Posted: Wed Jul 30, 2014 4:03 pm |
monley wrote: Jimny guys. Is this ring available separately? I had a look on the ORA site but could only see the full kit.
_________________ Quote: I like the tuna here
zukenutter
 Posted: Wed Jul 30, 2014 4:13 pm |
Send ORA an email
Blkfxx
 Posted: Wed Jul 30, 2014 5:56 pm |
zukenutter wrote: Send ORA an email Sent an email and no they don't sell them separately  Might have to DIY it.
zukenutter
 Posted: Thu Jul 31, 2014 7:06 am |
Is it for speedo? BigJimny had a "how to DIY WT swap" and they show how to make one from PTFE sheet and self tappers. Using this method you could add or subtract screws to correct speedo for bigger tyres
sj80tourer
Vehicle: sj80 coily
 Posted: Sun Mar 29, 2015 8:07 pm |
what reduction gears are tiu using in your wt case ?
sj80tourer
Vehicle: sj80 coily
 Posted: Sun Mar 29, 2015 8:42 pm |
where did you purchase the conversuon kit from i cant find it anywhere
zukenutter
 Posted: Mon Mar 30, 2015 6:55 am |
I used the standard gears, I don't need/want super low Low Range. I bought my kit directly from ORA but I think they're only available from JimnyBits now
GraphicX
Vehicle: 2000 Jimny
 Posted: Mon Mar 30, 2015 9:42 am |
i think ORA will make a kit for you but you need to contact them (they only make it after you order etc).
scottiej
Joined: Thu Nov 11, 2010 11:53 am Posts: 50 Location: UK
 Posted: Wed Apr 08, 2015 8:59 pm |
If you have 30/31" tyres fitted with a 1.58 ratio (in high) Tbox you can use a 27tooth ring to correct the speedo reading. You can make them out of one of the dog gears from a scrap sj transfer box, you just need to turn the centre out to the correct I.d. so that you can mount it on the output flange.
gutshot
Vehicle: suzuki sierra
 Posted: Wed Oct 26, 2016 7:14 pm |
will this kit fit an automatic gearbox jimny 1999 model
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Wed Oct 26, 2016 7:34 pm |
Yes. The transfer is mounted separately to the gearbox. Gearbox isn't relevant except for ratios.
