It is currently Wed Nov 04, 2026 9:07 pm
Post new topic Reply to topic  [ 130 posts ]  Go to page Previous  1, 2, 3, 4, 5
Vehicle: 90 SWB Vitara soft top 2' lift
Post Posted: Wed May 15, 2013 8:44 am
Ok thanks but incorrect of a Suzuki?
Post Posted: Thu May 16, 2013 8:00 pm
A safety point here guys. If you are rewiring the headlights you should fuse each side seperately. Not high and low beam. Point is that if a fuse blows you only lose one headlight not both. :?
SS
Post Posted: Sat May 18, 2013 7:22 am
Yeah that diagram is wrong, the wires have been crossed over between plugs, use my diagram thats here somewhere
Also most Hi and Low beam HID kits come with a separate battery supply, so you don't need to fit relays.
I don't agree about left and right fuses either, just fuse high and low beam, if one blows switch to the other.
Its also a massive amount of work to fuse left and right once you fit relays, you either need twice as many relays or make them negative switch which ups the amount of cable you use a lot
Post Posted: Sun May 19, 2013 9:05 am
ok thanks royce. i have HID hi low head lights already fitted so i just have to wire up the rely for some spotties
Vehicle: 98 jimny awning bar and lights
Post Posted: Sun May 19, 2013 1:13 pm
i didnt read whole thread but i had simmilar issues i bought a narva kit with a polarity reverser on it with is designed to run on veichles with suzukis type of high low beam setup was bout 80 dollars at supercheap pretty much plug and play setup too just had to shorten a few wires
Vehicle: 2007 Grand Vitara 2.7L
Post Posted: Tue Jun 04, 2013 8:47 pm
Mitchy wrote:
Hey Dan thanks for that, I went over to see your dad yesterday and he fixed it up so they come on by themselves. He said that your's was a pain in the arse to do. Now it is...
30 and 85 to positive battery terminal
87 to lights
86 to switch, then switch to earth
so now I have power and earth for both circuits :D
Hi Guys,
I know this has been flogged to death but I'm not great with this stuff.
I just wanted to check that if I do the wiring as above basically the spotties will come on if and when I flick the spotties switch with or without the lights/highbeam on. Oh and I'm not going to blow anything up?
Paul
Post Posted: Wed Jun 05, 2013 7:17 am
Never mind... taking the chicken track me thinks.
Post Posted: Mon Jul 29, 2013 2:29 pm
Thanks for this thread.
Not wiring in high beam spotties, though.
Doing a low beam triggered light.
But all basically the same, except the trigger wire will earth through low beam.
Vehicle: '11 GV3 2.4L
Post Posted: Mon Jan 12, 2026 3:32 pm
Apologies for the horrific gravedig, but I feel keeping my related post together is probably better over creating a new thread on the same thing.
As Marked mentioned on the previous page, the GV3 headlight plugs are different to the older zooks, having 2pin instead of 3. Took me a while of research I am still not quite sure how Marked wired his spotties up in the end but pretty certain it's not like how I have planned - Can someone help check to see whether the below (inside the blue dotted line) would work?
The last time I wired up spotties was over 20yrs ago.. with my dad on his old troopy. My highschool self managed to melt a good portion of the steering column harness. Dad wasn't too happy.
I'd like to avoid the same happening to my own car if possible 8O so if my diagram makes sense to others, I'll go ahead and cautiously try it out..
Seeing more than just road grime soonTM.
JT Grand Vitara Electronic Service Manual Guide
Post Posted: Mon Jan 12, 2026 8:02 pm
Yes, that should work.
Users browsing this forum: No registered users and 65 guests
