It is currently Sun Nov 15, 2026 10:42 am
Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
Vehicle: SJ80
Post Posted: Tue Oct 05, 2010 6:58 am
Probably a little late for this bit of info but if you have sierra extractors from the old engine you can grind off the flange and make a new one to suit. I took a g16 16v ex manifold gasket to a place with a laser cutter and they made me a flange from 10mm plate in the shape of the gasket. Cost me $20. Then I got a mate to weld the extractors to the new flange and weld a nut into the pipes for the exhaust sensor and presto. Works a treat. As a side note, for the fist couple of test drives before the exhaust was fitted I found it sounded better with just the original manifold than with just the extractors. That might have more to do with the extractors being longer but boy did it sound tough!
Vehicle: Zookless
Post Posted: Thu Oct 07, 2010 9:27 pm
I've fixed the temp gauge. It was upside down :roll:
This morning I drove up the road the the exhaust shop, got some strange looks going up the hill past the school :P
Not far into the drive, the temp gauge went up pretty high. Not quite in the red, but almost. I pulled over and the engine didn't feel that hot to touch. The gauge stayed where it was for the rest of the drive, only another 10 mins or so. When I got there, I felt the engine again and it seemed pretty normal.
As soon as the ignition is on, the gauge goes up about a quarter. I don't think the engine is running too hot, maybe I put the needle on the gauge a bit high?
edit: I ended up using the stock Baleno temp sender and Baleno gauge.
Vehicle: Zookless
Post Posted: Fri Oct 08, 2010 6:02 am
Jimny Hurricane extractors 8)
They clear the chassis rail by about 10mm. They don't "growl" as much as my old Lukeys, but it's still a nice note.
Finished
Thanks for all your help fellas! :wink:
Post Posted: Fri Oct 08, 2010 10:02 am
8) The eng Suzuki should of fitted.. :P
Post Posted: Fri Oct 08, 2010 10:13 am
very neat install 8)
Vehicle: Zookless
Post Posted: Fri Oct 08, 2010 10:28 pm
Here's the part number etc for the EXTRACTORS
I haven't been offroad for a proper test drive yet, but she absolutely hammers on the street 8O
Sideways out of roundabouts, burnouts, you name it. :twisted:
She even did 120km/h going UPHILL!
Post Posted: Fri Oct 08, 2010 10:55 pm
Very nice mate! welcome to the world of overpowerd sierras!
Post Posted: Sat Oct 09, 2010 3:16 am
Thanks for the exhaust number! Will be hunting for them for my lwb.
Post Posted: Sat Oct 09, 2010 4:34 am
I just got some efi vitara lukey extractors from eBay and a quick fit looks to clear might just have to take out a little of the engine mount bracket.
Post Posted: Sat Oct 09, 2010 11:00 pm
Did you put the air temp sensor in? cant see it in the pics.
They look a very nice fit. Are they the vl mounts? did you have to grind off the locating tab? Ive got them as as spare for when mine break just need to no if i need to grind the tab off so i can change them on track if i have to.
Post Posted: Sat Oct 09, 2010 11:54 pm
Yeah mate I just used a hac saw easy.
My Maruti build, Click WWW
Post Posted: Fri Oct 22, 2010 7:46 am
hey mate i am in tassie and about to attempt this conversion i was curious of what starter motor, flywheel and clutch set up you used
Vehicle: Zookless
Post Posted: Fri Oct 22, 2010 7:53 am
I used my original 1.3L starter, ground down so it will fit. (You can also use Vit 1.6. The Baleno starter has a different bolt pattern)
Original flywheel, machined and a new spigot bearing installed.
Excedy HD 1.3L clutch.
Post Posted: Sat Oct 23, 2010 9:47 am
cheers mate i am a fair way off. got the body sitting under the house chassis is off getting blasted been sitting at dodges for a while so she was a bit rusty. just wanna try to get all the info before i start looks like i will also have to buy the g13 starter and flywheel cause the car cam complete with no engine
Vehicle: Zookless
Post Posted: Sat Oct 23, 2010 9:55 pm
If you have to buy a starter, get a Vitara starter. It won't require any grinding.
Post Posted: Sun Oct 24, 2010 6:01 am
Reduction starter, mine sound's like a hot rod on start up.. :lol:
Post Posted: Sun Oct 24, 2010 6:56 am
i run a gti reduction starter
Post Posted: Sun Oct 24, 2010 8:06 am
where u get theat from mate?? interesting, how fast does it spin over?
Post Posted: Sun Oct 24, 2010 9:47 am
suzi auto spares.
its pretty fast actually
Post Posted: Mon Oct 25, 2010 7:47 pm
Mine doesnt need to spin over fast. Its normlly 1st or 2nd kick then she starts. With the machined down sierra starter.
Post Posted: Thu Apr 07, 2011 5:13 am
CairnsZook wrote:
Here's my "lengthened" Baleno fuel pump.
The return line is still a little short. I can't see it being a problem though, as the fuel will be returned to the swirl pot anyway.
hey mate that part with the gold tubes that bolts into the tank, whats it from?
Vehicle: Zookless
Post Posted: Thu Apr 07, 2011 6:13 am
If you use a Vitara EFI pump, it will bolt straight in.
Post Posted: Thu Apr 07, 2011 10:03 am
right. ive only got the actual pump part off a vitara. i wasnt sure what car u got the rest of the tubing stuff. when u said baleno pump i gathered u just meant the pumping mechanism
cheers
Post Posted: Thu Apr 07, 2011 11:26 pm
Yeah people on here just say vitara pump, but what they mean is the whole assembly.
If you go to a parts shop for a vit pump, all you get is the pump! No mountings! :lol:
Post Posted: Fri Apr 08, 2011 2:40 am
Did ur balano mounting plate thing fit ok into your coily tank? I just bought a vitara one today and some of the screws at the top of the tank don't line up :(
Vehicle: Zookless
Post Posted: Wed Apr 13, 2011 10:38 pm
My pump from a 2000 Baleno bolted straight into the Coily tank.
It all lined up perfectly. You did try rotating it didn't you? To get the holes to line up?
Edit: And notice the plug with the pink and black wires? That's from the Baleno too, made it nice and easy to wire up :wink:
Post Posted: Thu Apr 14, 2011 3:46 am
Hey man I ended up using the vitara plate. I just opened up some of the with a round file. The baleno one looks like a better choice. Those plugs are so much better. Mine is wired using crimp connectors.
Post Posted: Thu Jan 12, 2012 10:06 am
Can you take a photo for me of your exhaust. I got the same ones and it's hitting the gear box
Post Posted: Thu Jan 12, 2012 11:52 am
How much is it hitting the gbox/ block by?
My ones here, wildcat, jim extractors, used a ballpein hammer to make them clear nice.
They are totally different now though :lol:
Post Posted: Thu Jan 12, 2012 4:29 pm
Yeh was thinking about getting the hammer out lol
Thats it touching without doing any of the bolts up
Users browsing this forum: No registered users and 51 guests
