| Author |
Message |
Ratty562
Joined: Fri Apr 09, 2010 11:30 pm Posts: 839 Location: NSW, Sydney
 Posted: Fri May 06, 2011 6:38 am |
i went to see the price to day at BOC and they said they can do the welder and the bottle of gas of around $1000
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Fri May 06, 2011 7:27 am |
Ratty562 wrote: i went to see the price to day at BOC and they said they can do the welder and the bottle of gas of around $1000
How many amps is the welder??
_________________ Tell my arse, he actually gives a crap!
3cyl
Joined: Tue Jan 29, 2008 10:30 pm Posts: 2054 Location: Ipswich
 Posted: Fri May 06, 2011 7:53 am |
All the recognized brands are around the $1k mark. I settled with the Lincoln 180 for $1000 with wire, gauges/ regulator, it has the best wire feed assembly. The old Lincoln 170 which it replaces still goes but the newer model is heaps better. Inverter models are good to use but if the inverter card dies expect the card to be $600+. WIA and Lincoln are the only ones I saw that weren't inverter.
Bazooka
Joined: Wed Dec 22, 2010 9:12 am Posts: 38 Location: SOR Perth WA
 Posted: Fri Jun 03, 2011 7:31 am |
Looking at a new welder. Been using a gasless mig but some 'Little darling' decided they needed it (and a heap of tools as well) more than me.
So I do lots of light gauge (Body work) and some heavier (upto about 3mm) and wondering what would be best ...Tig or gas Mig. Im not a welders butthole but can lay a half decent bead. Was pretty good with an oxy back in my day too.
Suggestions?
mnemonix
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1409 Location: Newcastle NSW
Vehicle: '96 LWB trayback
 Posted: Fri Jun 03, 2011 7:32 am |
If you can oxy weld well, then tig is an option for you.
However 99% of home "welders" can't TIG for shit.
Gas mig is quick, painless and relatively idiot proof if you've got a general understanding of method.
Lash out on a good one. Lincoln, Miller, Migomag. Buy once and own it for life.
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Fri Jun 03, 2011 7:33 am |
Gas mig is easier and more efficient. TIG is IMO an artform that needs a skillful touch(no offense) Bang for buck go a MIG.....even stekky can use a MIG
jmd-247
Joined: Mon Apr 04, 2011 11:24 am Posts: 224 Location: THE BURGH!
 Posted: Fri Jun 03, 2011 7:36 am |
i recently bought a stick/tig welder, and i love it. was cheap enough and works great.
its a uni-mig ARC140 inverter welder.
with the tig attachments and gas, its great. welds the body panels great and can handle up to a 3.2 mm stick. so can handle larger stuff..
i love it..
but tig is hard!!
good luck
trity
Joined: Wed Jan 05, 2011 9:49 pm Posts: 250 Location: Perth, WA
 Posted: Fri Jun 03, 2011 7:46 am |
hahaha if i can mig anyone can mig
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Fri Jun 03, 2011 7:48 am |
I use tig for frame repairs, stainless and small work. Mig for everything else.
_________________ Watch out or you'll get sued.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Fri Jun 03, 2011 7:56 am |
TIG if yo is already a welder, MIG if your going to be doing home jobs.
reallyuted
Joined: Fri Nov 14, 2008 10:30 pm Posts: 253 Location: jimboomba se QLD
 Posted: Fri Jun 03, 2011 8:01 am |
why not buy both in one?
http://www.ebay.com.au/itm/UniMig-190Am ... 415a35cdad
i brought one of these a while ago for home and its great  i have gas mig welded 5mm thick rhs and tig welded my mates tank about .9 mild and have even used the gasless mig on 3mm gal rhs for a cheap welder i cant fault it yet.
p.s. can also buy a mini spool gun to mig weld up to 5mm ally (ill get one of these next month)
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Fri Jun 03, 2011 8:04 am |
31zook wrote: TIG if yo is already a welder, MIG if your going to be doing home jobs.
oi knuckle dragger.
some of us would get a bit of benefit from a how to mig weld stuff thread. just saying
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Fri Jun 03, 2011 8:05 am |
mig about 180 - 200 amps.
31zook
 Posted: Fri Jun 03, 2011 8:10 am |
shep wrote: 31zook wrote: TIG if yo is already a welder, MIG if your going to be doing home jobs. oi knuckle dragger. some of us would get a bit of benefit from a how to mig weld stuff thread. just saying
don't make me pound you goliwog
well...... there is good book to buy out there and it would require someone getting out there mig and taking allot of pictures......
DMAC
Joined: Thu Jan 29, 2009 10:30 pm Posts: 1612 Location: North Brisbane
 Posted: Fri Jun 03, 2011 8:46 am |
Just bought a inverter MIG/TIG/Stick Weldmaster 180 this aro.  Talked the guy down a bit too ended up costing just over a $1000 bucks.
Just need to wire in a 15A outlet and is all systems go again tomorrow.
It only took 2 years to completly destroy the little sip 100 gassless, then again I never knew what I was getting myself into with this Zuke stuff.
I'll report back on how it goes, then again maybe not as I won't be allowed near it if LTM21 gets his way.
_________________ SS
remydog05
Joined: Sun Nov 23, 2008 10:30 pm Posts: 1260 Location: Vic
 Posted: Fri Jun 03, 2011 9:37 am |
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5943 Location: Northcliffe, W.A.
 Posted: Fri Jun 03, 2011 10:29 am |
reallyuted wrote: why not buy both in one? http://www.ebay.com.au/itm/UniMig-190Am ... 415a35cdadi brought one of these a while ago for home and its great  i have gas mig welded 5mm thick rhs and tig welded my mates tank about .9 mild and have even used the gasless mig on 3mm gal rhs for a cheap welder i cant fault it yet. p.s. can also buy a mini spool gun to mig weld up to 5mm ally (ill get one of these next month)
We've got those at school. About as good as a welder gets really. I'm saving for one now.
Bazooka
 Posted: Fri Jun 03, 2011 11:02 am |
Thanks for the feedback guys. Been on you tube and watched some vids and I think I will get a mig / tig combo. Watched some tig vids and it got me all excited as I loved oxy welding and tig looks like a lot fun (Once mastered)
Now just wait for the insurance money then Im off for some retail therapy. Mmmmmmm tools !!!
something_else
Joined: Sun Apr 06, 2008 11:30 pm Posts: 819 Location: Pimpama
 Posted: Fri Jun 03, 2011 11:44 am |
I'm selling my Lincoln sp170 mig for 500 it's gas and gassless. They are a good unit. Too far away though
_________________ Lj81.
Ke20.
Baleno.
mightymouse
Joined: Tue Dec 29, 2009 10:30 pm Posts: 146 Location: Newccastle
 Posted: Mon Jun 13, 2011 10:53 pm |
Has any one on this site had anything to do with the 3 and 4 way combination welders and plasma cutters please post both good and bad reports so that I among others dont make a costly mistake. Thanking all and sundry in advance
_________________ growing old is nature, growing up is choice.
ajsr
 Posted: Tue Jun 14, 2011 12:20 am |
I have one that I boughta while back its a tig, plasma cutter and stick.
I only use the plasma cutter as I've really never found a tig better than my MIG unless its ally and same reason for the stick
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Tue Aug 09, 2011 6:08 am |
ok i want to buy an inverter.
i have about $300 to spend
will only be doing max of around 3mm stuff. maby a touch bigger..
would like it to have the compacity to be a tig.
suggestions.
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
jonno_racing
 Posted: Tue Aug 09, 2011 6:11 am |
ball
Joined: Wed Oct 22, 2008 10:30 pm Posts: 4673 Location: Katherine
 Posted: Tue Aug 09, 2011 6:22 am |
jonno_racing wrote: ok i want to buy an inverter. i have about $300 to spend
suggestions.
Is that before you whip out your concession card ?
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Tue Aug 09, 2011 6:29 am |
wait till you have $1k to spend
jonno_racing
 Posted: Tue Aug 09, 2011 6:32 am |
ball wrote: jonno_racing wrote: ok i want to buy an inverter. i have about $300 to spend
suggestions. Is that before you whip out your concession card ?
never gona drop that ya? ya gollywog..
nah shakes that is what i have to spend. i have found a few 170amp cig units that will do what i want. just wondering about opinions?
ball
 Posted: Tue Aug 09, 2011 6:48 am |
jonno_racing wrote: ball wrote: jonno_racing wrote: ok i want to buy an inverter. i have about $300 to spend
suggestions. Is that before you whip out your concession card ? never gona drop that ya? ya gollywog..nah shakes that is what i have to spend. i have found a few 170amp cig units that will do what i want. just wondering about opinions?
not a chance tubby
Mubby
Joined: Sun May 09, 2010 2:32 am Posts: 988 Location: Brisbane, South.
Vehicle: Jimny, Lifted on 30's
 Posted: Tue Aug 09, 2011 7:05 am |
I Bought A Weldcorp Arc welder 170 amp, Made my rear bar with it and also a few other little jobs that needed doing.. Has surved me well so far.
_________________ Jimny, 3" Lift, 30" Treps, Gears
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Tue Aug 09, 2011 1:38 pm |
ball wrote: not a chance tubby
Whoa fooking hell. No need to be racist here thanks.
banga
Joined: Tue Nov 17, 2009 10:30 pm Posts: 668 Location: sunshine coast
 Posted: Tue Aug 09, 2011 7:43 pm |
why dont you wait till you got $500-$600 then you can get an inverter mig the renegade are pretty good bang for your buck. we have a 160 at work and everyone who uses it is surprised with how good it is it'll weld 10mm plate to 4mm no worries.
_________________ lseries 2" body lift king springs 27" boots and a
