It is currently Mon Sep 21, 2026 8:13 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Vehicle: LJ80
Post Posted: Sat Jan 19, 2013 7:41 am
side bearing cap bolt 51-72lb
drive bevel gear bolt 58-66lb
differential case bolt 27-32.5lb
side bearing lock bolt 7 -10lb
differential carrier bolt 13.5-20lb
oil level & filler plug 25.5-36lb
oil drain plug 13.5-18lb
Post Posted: Sat Jan 26, 2013 9:14 pm
So do these spartan lockers go into the front 3.7 Sierra diff?
I'm confused as lowrange says they won't?
Also what other parts are needed to use 26 spline cromo cv's with it?
Post Posted: Sat Jan 26, 2013 9:21 pm
They will fit the 2 pinion front diff, I fitted mine to a 2 pinion Vitara diff.
But it will be stronger if fitted to a 4 pinion front diff.
Rear Sierra side gears are 26 spline.
Later model Vitaras have 26 spline fronts.
Post Posted: Sat Jan 26, 2013 9:27 pm
Thanks so would it be best to find a new rear center as they are 4 pinion and already 26 spline?
Post Posted: Sat Jan 26, 2013 9:30 pm
Yes I that would be best and easiest.
Post Posted: Sat Jan 26, 2013 9:31 pm
PS don't know if Maruti diffs are the same or not
Post Posted: Sat Jan 26, 2013 9:32 pm
4 pinion carriers have the cross pin block, too, which is needed
Users browsing this forum: No registered users and 131 guests
