It is currently Mon Sep 21, 2026 6:35 am
Post new topic Reply to topic  [ 134 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Post Posted: Sat Oct 09, 2010 7:38 am
Built4thrashing wrote:
have you tried a vit side gear in the sierra carrier?
or is it that the axle wont sild into where the side gear is.?
Im watching your progress closely as if it works i might do the same in my new GV
2 pin Vitara side gear has a strange shape around its edge that MAY foul the locker? 2pin Sierras may be same??
The Sierra carrier has a removeable bit to get at the innards. It holds the bearing too. The Vit axle wont fit thru it...tho You could get it milled out to fit, I think
Post Posted: Sat Oct 09, 2010 7:23 pm
joeblow wrote:
dimensionally they are the same, but some vits have 26 spline, and some sierras have a 4 pinion front.
trail tough says vit fronts are 3 pins, an email from them said it was very fiddly to fit and set up locker, so they sell it in the carrier
Mine is only 2pins, so think I'll put the sierra locker into my vitara carrier. Maybe not as strong as a 4pin, but I don't thrash it anyway.
Post Posted: Sat Oct 09, 2010 7:50 pm
I took a Vit carrier to an engineer shop (in Sydney) and had them drill a hole in the right spot to convert it.
It cost me about $50 but got me out of exactly the same situation you have.
Post Posted: Sat Oct 09, 2010 11:11 pm
Yes did have that thought this morning.
But I think 2 pins will be ok, hope I am right.
It is going in nicely.
Vit carrier also has a locating cotter pin, so shaft can't fall out..so much happier with that.
Think I am winning.
Post Posted: Sun Oct 10, 2010 4:50 am
Locker fitted perfectly into Vitara carrier.
Was unlocking on floor with lots of effort.
Hopefully driving will unlock it more easily.
Diffs back under car.
Can't test yet, need to fix up a cv boot and stuff,
and fit the drive shaft tomorrow.
Will hate wondering all night if locker will work right this time,
but I done for the day.
knackered and cussing too much, must be time to stop.
:cheers: :cheers:
Post Posted: Mon Oct 11, 2010 6:48 am
YAY TEAM
We are now locked up front.
No issues with using a Sierra auto locker into a Vitara.
As long as You have the 2 pin type, which every one seems to have.
And use Sierra 4 pin type side gears.
2 pin type MAY foul on locker
Same fitting technique, except you start at other end.
It took a while to free up, now it is much smoother.
Not as smooth as my rear Lock Rite, but it should bed in.
Thanks ALL for support, help, parts, and ideas along the way.
Post Posted: Mon Oct 11, 2010 8:58 am
christover1 wrote:
Not as smooth as my rear Lock Rite.
You have a lockright in the rear? whats the part number as i cannot get a definate answer from anyone if it will fit in a GV. Im hoping a sierra one will work as i already have one i can use.
Awsome work again mate.
Post Posted: Mon Oct 11, 2010 9:03 am
It was in car when I bought it.
Can't help with part number.
I will ask original owner, if he back from os.
pretty sure lowrange offer a rear lock rite for vits?
I believe back diff is is physically bigger and vastly different from the front.
I'm guessing Sierra lock rite won't fit in a rear Vit diff, but don't actually know.
Post Posted: Mon Oct 11, 2010 9:07 am
Only seems to list early model rear lock rite
http://www.lowrangeoffroad.com/suzuki/s ... ckers.html
Mines a 93 so it would be the one listed.
Looks like they changed something in later models.
Post Posted: Mon Oct 11, 2010 9:10 am
yeh i found that and have even asked the question but have not had a reply back yet. If i can hold of a rear ctr ill have a go at fitting it myself to see it it fits..
Hopefully Joeblow knows the answer and adds his 2c's
Post Posted: Mon Oct 11, 2010 9:12 am
well can you stick a vitara centre into the gv diff i thought it was possible
Post Posted: Mon Oct 11, 2010 9:14 am
It can be done to the front but rear is not knows yet
Post Posted: Mon Oct 11, 2010 9:15 am
rear vit diffs are cheap and plentiful,
probly as they last well, and usually dont get harmed in wrecks.
If an early model rear centre will go in, that could be good.
I don't mind the rear lockers handling, easy to adjust too, but I do dislike the drive line slack it produces, especially in an auto.
Post Posted: Mon Oct 11, 2010 9:41 am
drive line slack is due to it not being shimmed up properly. my font s perfect but rear has slop from the ctr not the pinion. a shim or 2 would tighten it up just nicely.
Post Posted: Mon Oct 11, 2010 9:48 am
Had to do that for rwc.
Was humungous slack.
Did ok.
But it could be better.
One day will reco back locker..
it is on to do list
Post Posted: Mon Oct 11, 2010 9:59 am
just like im on the wife's "to do list"
One day....
Post Posted: Fri Oct 15, 2010 9:17 pm
So have yu had time to test it out properly yet Chriss?
Got any bits left over i can check out? Did you end up using the GV ctr?
id be interested in getting it if its no use to you anymore.
B4t
Post Posted: Fri Oct 15, 2010 9:27 pm
B4t
GV centre, ring and pinion sold to a bloke in Tasmania, sorry,
the 4.3 ratio is a good thing for some Jimnys apparently.
I have used it in 4wd only on dirt roads,
it is getting smoother with use.
Running in I guess.
Going out with club on easy day tomorrow,
I should be able to test it better then.
PS I still have the sierra rear side gears if you want them.
Post Posted: Tue Dec 04, 2012 8:25 pm
grave dig.
so this ended up with gv steel housing, vitara centre, vitara side gears? (mine are 26 spline) and sierra spartan locker
how do you like this in the front, as in effects on steering?
mainly just bumping this so i can find it again
Post Posted: Tue Dec 04, 2012 8:37 pm
Yes that is correct, I'm using 22 spline, as I had lots of them spare.
I'm loving it. Steering is plenty easy with Vit power steer.
Sometimes in slimy stuff, needs a power squirt to get a direction change.
Rarely makes any noise.
Extremely happy.
No broken CV's since fitted
Post Posted: Tue Dec 04, 2012 8:39 pm
Also running a right hand stubby conversion with a support bush.
Vehicle: 96 vit hardtop
Post Posted: Wed Dec 05, 2012 10:15 am
And i was ' ' this close to buying a chinasoong air locker for my vit...
am now looking into this, glad this thread got re jigged up...
Should be sweet with 26 spline yeah?
Post Posted: Wed Dec 05, 2012 2:34 pm
same here!
btw lowrange offroad has spartan lockers on sale atm for 203$ (or lockright is 206$ normal price)
thanks alot for the reply, and the original tech christover :peaceout:
Post Posted: Wed Dec 05, 2012 2:38 pm
W000000000000t time to buy one then!
Just not 100% sure which one im spose to get for my vit..
Post Posted: Wed Dec 05, 2012 2:42 pm
yep im about to do the same :D
they only have the one without couplings listed on there so cant go wrong
this one http://www.lowrangeoffroad.com/index.ph ... uzsam.html
Post Posted: Wed Dec 05, 2012 2:45 pm
are you also getting the side gears or running the vit ones? Ie. The ones without the lip.
Post Posted: Wed Dec 05, 2012 4:40 pm
im gunna use mine, when i did the rear lockright i used my no lip side gears with a sierra 1510 lockright and worked fine
Post Posted: Wed Dec 05, 2012 7:34 pm
viewtopic.php?f=17&t=15661
A related thread that may help.
Post Posted: Wed Dec 05, 2012 11:30 pm
Righteo. I've done all the reading on earth.
Its clear now that I can get the spartan locker into the vitara carrier, even though its a two pin. I guess you just dont use the other pins.
Did you use the shims also? or does the spartan not come with shims.
with the side gears, i notice you say you used your sierra ones without the lip... So I'll pobably have to buy those side gears , without the lip as the vitara one i have has the lip.
Post Posted: Thu Dec 06, 2012 6:40 am
People have told me they have used the lipped gears with no problems.
No body has said they didn't work, so I guess it is up to you.
Yes just leave out the cross pin not needed, or some people get centre drilled to accept the extra pins.
I didn't, not had any problems, though may be a good idea.
Spartan instal instructions stress that shims not be used,
I guess the machined to fit without.
I removed all my shims,
ir runs smoother than my lock rite one.
Users browsing this forum: No registered users and 131 guests
