It is currently Wed Nov 04, 2026 11:50 pm
Post new topic Reply to topic  [ 110 posts ]  Go to page Previous  1, 2, 3, 4
Vehicle: 98 Jimny
Post Posted: Mon Jun 23, 2014 8:42 pm
my speedo isn't working anymore :( Did anyone work out what causes this to happen??
Post Posted: Mon Jun 23, 2014 8:55 pm
my guess would be it's most likely the spacing between the speedo cog & the sensor.
Post Posted: Mon Jun 23, 2014 9:06 pm
Do you have the old kit with enclosed speedo adapter or the newer open style?
Checked the wiring?
Mine has never stopped working but that could have something to do with my dislike of mud.
Vehicle: 98 Jimny
Post Posted: Thu Jun 26, 2014 10:03 pm
i have the new one. i think the nuts bolts on the flange have hit the sensor, there is plastic on a couple of ends of the bolts soo sadly thats what i get for doing the conversion at late times of the night :( there is a small bit of plastic missing of the side facing the bolts must of been enough to break the sensor :(
Vehicle: 98 Jimny
Post Posted: Thu Jun 26, 2014 10:20 pm
:(Broken sensor i guess :(
Post Posted: Thu Jun 26, 2014 10:23 pm
look how long your bolts are... those 2 were always going to try & make babies. :(
Post Posted: Fri Jun 27, 2014 7:03 am
Sounds like you found your problem. On a side note, the new kit seems to position the sensor quite off line from the ring. Looks to be all in the right positions but strange that they haven't positioned it a bit closer to the transfer.
Vehicle: 98 Jimny
Post Posted: Fri Jun 27, 2014 9:56 pm
i did it really late at night/early in the morning hoping to be done for cruiser park that morning :(
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Wed Jul 23, 2014 6:40 pm
Any word on the speedo fix? Just done my install and i also have no speedo!!!
Vehicle: Drover pickup turk
Post Posted: Wed Jul 30, 2014 4:03 pm
monley wrote:
Jimny guys.
Is this ring available separately? I had a look on the ORA site but could only see the full kit.
I like the tuna here
Post Posted: Wed Jul 30, 2014 4:13 pm
Send ORA an email
Post Posted: Wed Jul 30, 2014 5:56 pm
Send ORA an email
Sent an email and no they don't sell them separately :(
Might have to DIY it.
Post Posted: Thu Jul 31, 2014 7:06 am
Is it for speedo? BigJimny had a "how to DIY WT swap" and they show how to make one from PTFE sheet and self tappers. Using this method you could add or subtract screws to correct speedo for bigger tyres
Vehicle: sj80 coily
Post Posted: Sun Mar 29, 2015 8:07 pm
what reduction gears are tiu using in your wt case ?
Vehicle: sj80 coily
Post Posted: Sun Mar 29, 2015 8:42 pm
where did you purchase the conversuon kit from i cant find it anywhere
Post Posted: Mon Mar 30, 2015 6:55 am
I used the standard gears, I don't need/want super low Low Range.
I bought my kit directly from ORA but I think they're only available from JimnyBits now
Vehicle: 2000 Jimny
Post Posted: Mon Mar 30, 2015 9:42 am
i think ORA will make a kit for you but you need to contact them (they only make it after you order etc).
Post Posted: Wed Apr 08, 2015 8:59 pm
If you have 30/31" tyres fitted with a 1.58 ratio (in high) Tbox you can use a 27tooth ring to correct the speedo reading. You can make them out of one of the dog gears from a scrap sj transfer box, you just need to turn the centre out to the correct I.d. so that you can mount it on the output flange.
Vehicle: suzuki sierra
Post Posted: Wed Oct 26, 2016 7:14 pm
will this kit fit an automatic gearbox jimny 1999 model
Post Posted: Wed Oct 26, 2016 7:34 pm
Yes. The transfer is mounted separately to the gearbox. Gearbox isn't relevant except for ratios.
Users browsing this forum: No registered users and 32 guests
