It is currently Fri Nov 06, 2026 2:05 am
Vehicle: 91 Sierra
Post Posted: Fri May 07, 2010 4:16 am
Some links to AZ dash builds, dash tech, and other dash related stuff;
WT Dash into a NT discussion, what do you need. - link fixed
WT Dash into a NT discussion, troubleshoot. - link fixed
Coily dash into a NT ( soo... who's going to do a decent dash swap thread ? )
NT Dash with Tacho factory option. - link fixed
Where to put stereo in a NT Dash chat - link fixed
Where to put Air Locker Switch chat - link fixed
Where to put additional gauge chat - link fixed
Dash Fan / Heater box discussion, how to clean out or fix.
Dash Fan / Blower only works on high discussion, how to fix.
Custom Dash from aluminium by pyrohamish.
Custom Dash from chequer plate by barneyszookin
Custom Digital Speedo / Odometer build by JrZook.
VSS DIY speedo mod for 1.6 efi by Damo
VSS DIY speedo mod for 1.6 efi by JrZook
btw VSS = Vehicle Speed Sensor. :)
If you have a dash different to the ones posted below, post up a pick.
cheers.
Vehicle: 91 Sierra
Highway-Star, LJ81/LJ80 (pre-stockman), Notice the big vacuum pump for the window washers on the dash board :) : That radio is butchery, and not standard, should be an ash tray there.
[hr]
Highway-Star, LJ80/LJ81 "Stockman", notice the washer and wiper controls are now on the steering column, and the instrument cluster is now plastic. also the heater box is different, and the factory radio is where the ash tray used to be, so the ash tray is now in front of the heater box:
[hr]
Rhino, 1982 SJ41 1l, including original am fm radio :D
[hr]
Have you got poverty pack or the Luxury dash, 303zuke wrote :
The NT (or "Round Vent") JA dash.
There is an uncut blank spot for the clock ( center of dash ) with plugs in the holes for the soft crash pad. The gauge cluster does not have a tacho. The warning / idiot lights are vertical between gauges.
The NT (or "Round Vent") JX dash,
Has a soft crash pad on the left side with a digital clock. The Speedo gauge unit has a Tacho on the right and the warning / idiot lights horizontal below the gauges. The round air vents look the same on the two versions, but are long or short depending on if the crash pad is fitted. The 'Round Vent' dash only came in Grey.
The WT (or "Square Vent") JA dash,
Has no clock, and the gauge cluster has no tacho. Like the NT JA, The warning / idiot lights are vertical between gauges.
The WT (or "Square Vent") JX dash,
Has the digital clock and tacho and the Speedo gauge unit has a Tacho on the right and the warning / idiot lights horizontal below the gauges.. As there was no add-on crash pad with the Square Vent dash, the air vents are the same on both types. The 'Square Vent' dash came in either Dark Grey or Brown.
[hr]
shep, 1985 lwb NT in Sierra SJ51 JX dash, freshly hosed down. and proud of the clock :wink:
[hr]
BlueSuzy, 1988 Lwb WT in Sj51 JX dash, 1324cc , with AM radio.
[hr]
1990 Lwb NT Maruti, JA dash, airconless with red dust highlights.
[hr]
303zuke 19?? WT JA dash,
[hr]
BlueSuzy, 1991 Swb WT Sj70 JX Dash, 1298cc
[hr]
bagnkat. 06/98 sj80 coily dash with light grey trim. The early coilies had a darker grey trim. This dash has factory airconditioning. Visible in the driver's side photo in my post at bottom of page are aftermarket diff lock switches, spotlight switch and imobiliser indicator.
[hr]
Vitara's, X-90 and Jimny's;
Hmmm, hadn't really considered other Zook Models .... but just for curiosity sake i'll add one jimny dash, thats it !
This little black duck has no plans to expand this post outside the LJ to Coily zone :wink:
[hr]
BlueSuzy, 00' model Jimny JLX m13a auto . Twin airbags. Power mirror controller in rhs under steering wheel. (cdplayer and digital clock not shown) Lever Transfer. Centre console has arm rest in cup holders.
[hr]
aftermarket example from the states 8)
Post Posted: Fri May 07, 2010 4:26 am
here is mine. sj51. hosed the dash 2 days ago, clean hay.
Post Posted: Fri May 07, 2010 4:27 am
the clock works as well :lol:
Vehicle: Suzuki
Post Posted: Fri May 07, 2010 4:34 am
lauby wrote:
no zoom
What if I can't fit it all in?
lauby wrote:
taken at night with a flash.
Why not during the day with no flash?
Vehicle: 91 Sierra
Post Posted: Fri May 07, 2010 4:53 am
foonji wrote:
lauby wrote:
no zoom
ha, a zook dash is only about a metre wide, it'll fit and have a look at sheps picture taken during the day, there's shadows across it hiding some of the shiney clean bits.
Post Posted: Fri May 07, 2010 5:03 am
1991 Swb Sj70 1298cc WT Dash
Same Dash is in a 1988 Lwb Sj51 1324cc WT. But with AM radio.
Im thinking those flaps next to the clock must of been an option!
Both have no Aircon.
Mates 94' Swb sj70 1298cc Wt had same dash but with button for aircon. Original.
Vehicle: 92 Suzuki Sierra
Post Posted: Fri May 07, 2010 7:36 am
Could work, be good to add a shot of the gauge clusters and any funky Dash OEM options
Eg Inclonometer on WT Dash, Tacho and non tacho options (like the NT? did it come in a different style to NT with tach!?)
looks like i need to hunt down a digital clock for the lwb... don't like the thought of shep being excluisive.....
-Santos
Post Posted: Fri May 07, 2010 7:52 am
I put a NT dash in my 82 1L Sierra, cars stock. Apart from a 6point
cage and the dash.
Vehicle: '94 suzuki maruti
Post Posted: Fri May 07, 2010 8:53 am
yep. i have a '94 SWB WT sj70, exactly the same... except mines a little shinier, no CB, and wires hanging out the bottom, im guessing from the previous owners home-done stereo install (which, by the way, was the worst job ive ever seen! gunna fix that up sometime soon)
Post Posted: Fri May 07, 2010 11:12 am
Alot have wires hanging down from dodgy installs.
There are covers that go underneath, but they are as rare as the dash pocket door/flaps..
Vehicle: 91 Sierra
Post Posted: Mon May 10, 2010 2:28 am
want33s wrote:
Never happen here mate... Everyone likes looking at pics not taking them.
C'mon, we almost have the full set, calling on one or two coily and LJ owners to prove Jas wrong :lol:
Also, did you know the word ' dash ' is mentioned in 1030 posts on AZ .... 1031 now :roll:
Post Posted: Mon May 10, 2010 3:01 am
Clearance Hole Technology :P
Post Posted: Mon May 10, 2010 4:34 am
we still need the early 1l SJ40? SJ410? semi-metal dash
-Santos
Vehicle: SJ80
Post Posted: Mon May 10, 2010 4:10 pm
06/98 sj80 coily dash with light grey trim. The early coilies had a darker grey trim. This dash has factory airconditioning. Visible in the driver's side photo are aftermarket diff lock switches, spotlight switch and imobiliser indicator.
Vehicle: SJ80
Post Posted: Mon May 10, 2010 4:28 pm
I'll increase the image size soon.
Post Posted: Tue May 11, 2010 9:09 am
96 coily, just mounted the spottie switch in the most obvious place possible
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Wed May 12, 2010 7:05 am
Here you go.
Sierra 1l dash including original am fm radio :D
Post Posted: Wed May 12, 2010 8:36 am
Rhino wrote:
Here you go.
I got one out of a n/t, has a flash tape deck to... :P
Missing a knob tho :cry: :lol:
Post Posted: Wed May 12, 2010 1:12 pm
Sheps is a sj51 NT
Its weird that they used the same SJ51 for all LWB..NT and WT..
Vehicle: LJ50V, SJ70
Post Posted: Wed May 12, 2010 3:26 pm
And Shep and BluSuzy's LWBs are both "JX" spec, the luxury version of the Sierra with the clock and tacho. The other type was the "JA" basic spec.
The NT (or "Round Vent") JA dash is the type fitted to the pictured Maruti. There is a uncut blank spot for the clock with plugs in the holes for the soft crash pad, and the gauge cluster does not have a tacho. The idiot lights are in the middle of the 2 dials.
The NT JX dash has a soft crash pad on the left side with a digital clock. The Speedo gauge unit has a Tacho on the right and the idiot lights across the bottom. The round air vents look the same on the two versions, but are long or short depending on if the crash pad is fitted. The Round Vent dash only came in Grey.
The WT (or "Square Vent") JA dash has no clock, and the gauge cluster has no tacho. Like the NT JA, the idiot lights run up the centre.
The WT JX dash has a digital clock and tacho and the idiot light run along the bottom of the gauges. As there was no add-on crash pad with the Square Vent dash, the air vents are the same on both types. The Square Vent dash came in either Dark Grey or Brown.
Post Posted: Wed May 12, 2010 3:33 pm
i'd just like to say what a top effort lauby has done to compile this thread & top job on everyone else who's submitted tech/info! 10/10 Armsup
Post Posted: Thu May 13, 2010 2:19 am
Whens the Vit models, X-90 and Jimny's happening? :D
Post Posted: Wed Apr 04, 2012 4:48 pm
Just found this thread but the links in the first post don't work (just brings you to the main page)
Maybe it had something to do with the forum upgrade?! Would be good if they could be fixed for the tech section :)
Post Posted: Sun Jun 23, 2013 11:49 am
whats needed to put the 1.3 n/t dash into the 1.0 body?
 Profile YIM
Post Posted: Sun Jun 23, 2013 5:00 pm
If the 1.0 has a steel dash you need to cut it all out and then remove the 1.3 dash along with all the spotwelded brackets and attach them to your 1.0.
It is a HUGE job to get right. You really need to swap in the whole 1.3 firewall to make it all work.
Post Posted: Mon Jun 24, 2013 11:55 am
ok thanks jas
 Profile YIM
Users browsing this forum: No registered users and 51 guests
