It is currently Sun Nov 15, 2026 3:04 am
Post Posted: Tue Nov 02, 2010 11:30 pm
Anyone recommend a descent place in Briz where I can get 'quality' uni joints and both the sierra jack and rear driveshafts balanced? Trip back home to cairns at the end of the year so I need to get rid of any vibrations! Drive you nuts after 1800k's!!
Lil Foot!
Post Posted: Tue Nov 02, 2010 11:54 pm
x2 in terms of relevance to my interests... :P
And idea on costs etc?
Post Posted: Wed Nov 03, 2010 12:00 am
It was a while ago but i used DRIVELINE SERVICES AUSTRALIA PTY LTD
in archerfield, cost me 150 for a custom tail shaft build and balance. would says its a bit more now but they do good work.
what do you need one for john?
Post Posted: Wed Nov 03, 2010 12:01 am
What do you mean by quality Uni Joints?
Just ask a Repco or something.. Uni joints don't differ in quality that greatly for it to matter in a Sierra.
As for the tailshaft, maybe try a gearbox n diff place?
Post Posted: Wed Nov 03, 2010 12:14 am
A quality uni joint in my books is a joint that has sweet FA slop on both its axis and stays like that for more than at least 10000k's. The majority of the junk out there already has like 0.5mm movement on both axis when freshly installed and no the driveshaft ears have not splayed apart. Even when I shim the faces to get rid of the initial slop its back again not long after and exaggerates the driveshaft vibrations.
Lil Foot!
Post Posted: Wed Nov 03, 2010 12:39 am
BWAHAHAHAHA I once bought a heap of uni joints for $4 each, they fit perfect but lasted about 6 months
Post Posted: Wed Nov 03, 2010 12:41 am
i think if you use it for wheeling, your asking alot for them to last very long.
never had any issues with ones from a normal bearing store
Post Posted: Wed Nov 03, 2010 12:47 am
Just vibrations and so fourth... Its nothing major but if it was cheap anough to do i'd be silly not too.
Post Posted: Wed Nov 03, 2010 12:51 am
i will find out how much they are again soon as i need to get a jack shaft made up for Jenna
Post Posted: Wed Nov 03, 2010 12:58 am
x2, i have had stuff done by them down here, great service
Driveline services
56 colebard street east
acacia ridge
ph - 0732757600
weaves
Post Posted: Wed Nov 03, 2010 2:07 am
Driveline services
acacia ridge
ph - 0732757600
weaves
Cheers guys, I shall suss them out!
Lil Foot!
Post Posted: Wed Nov 03, 2010 3:39 am
Steering clear of mud, i cant see how you did that =P
I've never chewed through one in anything under 2-3 years.. And i buy them off ebay or my local Repco-lookalike
Post Posted: Wed Nov 03, 2010 6:17 am
http://www.hardyspicer.com.au/driveline_products.asp
I have NEVER had any drama's with this mob..
Post Posted: Wed Nov 03, 2010 7:35 pm
What it comes down to generaly is the quality of the metals used, and the hardening process's on the raceways and rollers. Besides the fact that alot of chinese product are out of tolerance, they use a tainted metal, which in alot of cases means softer, and or brittle metal.
if your using it in low shockload, low revolution application your going to be ok. But you start loading these things up and they chew out very quick
Post Posted: Wed Nov 03, 2010 10:40 pm
Ah i hadn't thought about metal quality.. They have bugger all QA systems inplace to check for faulty parts too..
My Zook lives a pretty stress free livestyle, so yeah no dramas with cheapo Uni's yet
Post Posted: Wed Nov 03, 2010 11:04 pm
Id use these guys over driveline services Without a doubt
Post Posted: Wed Nov 03, 2010 11:46 pm
x2 for Driveline Services, they built my rear diff and axles from scratch for a touch under $600, that included everything
but oil and center.
Post Posted: Wed Nov 03, 2010 11:48 pm
Why?
i've never had a problem with Hardy spicer either, their product and service are fantastic, i just use driveline as they seem more approachable and better priced with just as high quality product (around here anyway).
weaves
Post Posted: Thu Nov 04, 2010 4:54 am
Just gave driveline services a burl. Their after $220 per shaft for new unis and balancing. Makes your custom shaft seem cheap! :wink:
Lil Foot!
Post Posted: Thu Nov 04, 2010 4:55 am
yeah sept that was about 7-8 years ago lol
Post Posted: Thu Nov 04, 2010 9:33 am
Why?
weaves
Have had a few problems with them through my old work and once personally.
Hardy spicer shortened a jackshaft for $110 including freight with a 2 day turn around and i had absolutely no issues with it. Very good service
But thats just my personal experience and opinion.
Users browsing this forum: No registered users and 67 guests
