It is currently Fri Nov 13, 2026 5:43 pm
Post Posted: Tue Oct 05, 2010 7:09 am
Looking for pics/suggestions of how people have adapted the roctoy ring to strenghten transfer case/mounts.
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Tue Oct 05, 2010 8:38 am
Incorprated it with a Mighty kong and welded the two together, with a bit of wiggling the transfer case does still slip in and out
Post Posted: Tue Oct 05, 2010 8:42 am
Post Posted: Tue Oct 05, 2010 10:06 pm
Always liked the roctoy but never understood how it works, my understanding, you weld it to your bracket, and it creates more fixings points for your tcase to fix to, thus spreading out the load of the case?
Amiright?
Post Posted: Tue Oct 05, 2010 11:39 pm
yep basically thats it. But then the increased touque generated goes to the mounts. So if there not strong enough they will bend, causing the transfer case to twist. I assume this would destroy the output shaft.
Post Posted: Tue Oct 12, 2010 7:57 am
Got my gears and roctoy ring. Will be doing something similar to Brendan ( above post) to transfer mounts. That seems strong enough for the driving il be doing. Nothing exteme.
Post Posted: Tue Oct 12, 2010 8:47 am
you can kinda see mine in this pic:
It's being used in combination with one of these: http://www.suzistore.com.au/shopexd.asp?id=1411 (mine was the prototype).
Post Posted: Wed Oct 13, 2010 7:06 am
heres mine
 Profile YIM
Post Posted: Wed Oct 13, 2010 8:14 am
Mine during the build.
there was more plate added tho.
Post Posted: Sat Oct 16, 2010 4:57 am
Do you need 6mm longer bolts when fitting the roctoy or do you still use the standard?
Post Posted: Sat Oct 16, 2010 10:23 am
I had to use spacers on some bolts as the ring does not sit flush with the case, not a problem but you so need longer bolts on some holes?
Post Posted: Sat Oct 16, 2010 8:38 pm
Definitely need longer bolts for some of the holes.
Post Posted: Sat Oct 16, 2010 9:08 pm
yeah i went all out and replaced all the bolts with 8,8's very over kill, but every bolt has a flat and a spring washer 2.
i think i still have my bolt shoping list here somewhere.
Post Posted: Sat Oct 16, 2010 9:15 pm
OH and I also used quite a LOT of washers to make up for the spacer gaps in between the flat surface of the ring and the uneven bolt heights on the case.
Ive seen a few cases where people have just tightened them up with no spacers.. :o
Post Posted: Sat Oct 16, 2010 9:26 pm
wow rly? i used washers 2... worked well.. tighting without washers would put epic pressuer on the case! silly people
Post Posted: Sun Oct 17, 2010 1:08 am
Do you know the bolt sizes yous used. i got a mechanic mate doing mine, so il have to let him know before he puts it all back together and to space it where nessacary.
Post Posted: Sun Oct 17, 2010 2:54 am
can you run a rocktoy ring with out body lift ? because i think a read somwhere that it hits on the tunnle if you havent lifted the body. any advise on this? cheers fellas
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Post Posted: Sun Oct 17, 2010 3:17 am
mines pretty similar to jimbos with a few flats running back down to the arms for strength.
i used some of the longer bolts in place of the shorter ones when putting it back together using washer where packing was needed and the remaining ones i got 10mm longer bolts that whatever the longer ones allready were.Was over 2 years ago so dont remember length but they are M8
Post Posted: Sun Oct 17, 2010 4:07 am
i run mine with no BL... clears by a few mm =)
Post Posted: Mon Oct 18, 2010 10:15 pm
If you look at jimbo's he's runnin a BL and a TL so that'd be simialr to standard clearence.
Post Posted: Mon Oct 18, 2010 10:20 pm
intresting..
i have a 2inch bl
i tryed to lift the transfer 40mm it foud hard!
30mm transfer lift and it JUST clears.
Post Posted: Tue Oct 19, 2010 7:14 am
jonno_racing wrote:
intresting..
i have a 2inch bl
Agreed..
I run 50mm rubber blocks on mine.. and had to shave approx 20mm off the corners of the ring (had a lot of meat on them so taking that much off wasnt much of a problem.)
Post Posted: Tue Oct 19, 2010 10:25 am
i have 2" bodylift. and lifted my case with some 65x35 rhs as 35s all i could go without the case hitting in a few spots SO.....one day ill notch some of the ring and go higher with the case
Post Posted: Tue Oct 19, 2010 11:35 pm
I run 2" Bl with 2" transfer lift and roctoy with extra plate, Reinforced original arms to look stock, but double the thickness.
Shaved top of ring, and hammered/cleared floor tunnel for the sides.
Link to the page in the build http://www.auszookers.com/index.php?nam ... &start=150
Vehicle: 93 Sierra
Post Posted: Sat Oct 23, 2010 1:48 pm
Not at all. 6mm plate in its weak axis bends pretty easily. I used a couple of 2mm washers in one location to space the ring out (last hole on one end) but for the rest just gradually tightened up the bolts. The plate deforms plastically (ie doesn't try to spring back) and that's it - ring is formed to the correct profile. You can pull it off at that stage and it will hold it's shape ... I did for painting and welding.
Vehicle: Work van
Post Posted: Wed Dec 15, 2010 5:05 am
Hey guys roctoy ring showed up today, I'm just wondering if 3mm plate will be strong enough to brace my tcase arms and fussed the ring to the arms, only going to use 3mm because I have some laying around
Josh
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Wed Dec 15, 2010 5:21 am
Josh
If you do it right you should be fine.
Are you a good welder?
Vehicle: Work van
Post Posted: Wed Dec 15, 2010 5:38 am
I'm not but I am only going to tack it all up how I want it and get a friend who is a trade welder to finish weld it
Post Posted: Wed Dec 15, 2010 5:44 am
Well wenever using lighter gauge materials as a strengthening medium, 'boxing' or ' closing' sections adds to their rigidity.
Putting folds or bends in it also gives strength when done correctly.
And I suppose you don't have access to any dimple dies? :lol:
Vehicle: Work van
Post Posted: Wed Dec 15, 2010 6:10 am
I wish dimple dies are so 8) I was thinking of use the 3mm to box the long arm and strengthen the short are and getting some 6 to gusset the ring back to the arm?
Users browsing this forum: No registered users and 51 guests
