http://auszookers.com/forum/
Basic Chain Axle Puller
http://auszookers.com/forum/viewtopic.php?f=17&t=19477
Author:  steve [ Fri Feb 25, 2011 9:55 am ]
Post subject:  Basic Chain Axle Puller
Here's a basic chain axle puller.
Stick your hub on backwards, grab a bit of chain and run in around the hub, grab a big hammer or big bit steel and do a bit of a whack motion outwards.
The photos probably explain it better.
Author:  ninjamoses [ Fri Feb 25, 2011 10:00 am ]
Post subject:  Re: Basic Chain Axle Puller
Gotta love backyard tech :)
My way of doing it for the Vit...
1) Take the wheel off and undo whatever you need to (drum brake/axle bolts etc).
2) Put wheel back on and do the wheel nuts up just a few threads each
3) Get yourself in position, and yank the wheel as hard as you can :)
Only has above 10 - 15mm of movement before it hits the wheelnuts, but with the weight of the wheel behind it she usually comes off with just one or two pulls.
Author:  joel [ Fri Feb 25, 2011 10:01 am ]
do you and shep share the same double helix? he will love this, than copy the idea, but the chain will become telecom rope and the hammer will be a lump of metal he found at the dump.
looks pretty good, cheaper than a proper puller.
Author:  weaves [ Fri Feb 25, 2011 1:45 pm ]
i usually just chuck on of the spare 10 rims i have here on and bash it with a rubber mallet. always worked for me.
This idea i will keep in mind though times the above method does not work
Author:  31zook [ Fri Feb 25, 2011 6:11 pm ]
X2 since you showed me that i have never tried anything else...... works great :D
Author:  zukenutter [ Fri Mar 04, 2011 7:49 am ]
I use an old brake rotor turned backwards, three studs and lugs a couple of threads and use the rotor as a slide hammer.
All of above sound good too.
Author:  Daves4wd [ Tue Dec 27, 2011 12:39 pm ]
I found the easy way in a Sierra is to undo all the bolts and use the backing plate a slide hammer if that makes sence one good pull and shell pop out pretty easy just make sure you don't hit any important bits hahahha
