It is currently Sat Nov 14, 2026 10:17 pm
Vehicle: 75 Cruiser
Post Posted: Fri Feb 25, 2011 9:40 am
I thought i better try bring some kind of tech?
I put a minispool in the X90 on the weekend, (with the assistance of nissvit)
I got a couple of them from Lowrange, general minispools for Sierra/Vitara/X90, ordered and all arrived ok within 2 weeks so that was good, got a few stickers in there too, should be good for holding loose panels on.
Welp, it seems that my X90 rear diff is different to every other one out there because the minispool didn't fit. We had to grind down the minispool. No, there was no way it was going just bang in with a hammer. I stuck the verniers on there and it would have to be 0.3mm difference, so the side gears slip in easily, where he minispool had no chance of fitting. anyways.. here's some arty farty pics for effect...
Post Posted: Fri Feb 25, 2011 9:49 am
8O I hope that lath is spinning away from Mr Niss....
:P good work tho.
Post Posted: Fri Feb 25, 2011 10:27 am
Looks like Mr TOYvit is doing all the work :lol:
Vehicle: 75 Cruiser
Post Posted: Fri Feb 25, 2011 10:38 am
It's hard to take photos of myself doing it. I think we do a fair it of work equally. We share the load and costs. If you can hook up with someone and share work and costs it makes for a good team.
Post Posted: Sun Feb 27, 2011 3:18 am
:P good work tho.
With a good hold on the file, whats the problem?
A file won't work going the other way.. Bit like a hacksaw.
Good work. More good info on auszookers :wink:
Vehicle: 75 Cruiser
Post Posted: Sun Feb 27, 2011 4:16 am
PS. The file hardy did anything, so Chris tried to use the lathe bits (what ever they're called i can't remember) ,but they went blunt straight away, so the minispool is pretty hard stuff. He ended up using a grinder to grind it on the lathe and then the file was to smooth it off.
Post Posted: Sun Feb 27, 2011 6:44 am
Probably be the same stuff as the axles.
Carbide will machine it, but not hss
Post Posted: Sun Feb 27, 2011 7:17 am
:P good work tho.
Gee, grabbing & being shoved into his for arm, nothing much, sorry I mentioned it... :roll:
Post Posted: Sun Feb 27, 2011 8:24 am
steak_knife wrote:
:P good work tho.
They are dangerous without a handle..
Post Posted: Sun Feb 27, 2011 9:26 am
its about the only option with a file on the lathe taking off sharp edges or rounding off corners. Yes a handle on them is a great idea.
ive had a couple have a little grab but if you are aware at all times on the lathe things normally go fairly smooth.Just dont put stupid pressure on it also.
Carbides FTW allthough at home i guess people dont wanna spend the coin at times.
Vehicle: LWB Sierra & XL7
Post Posted: Sun Feb 27, 2011 9:45 am
I don't suppose you have a photo of it just before re-installation?
And did it come with full destructions on how to install it?
'92 Vitara & Camper trailer
Vehicle: 75 Cruiser
Post Posted: Sun Feb 27, 2011 6:10 pm
What do you mean "before reinstallation" ?
nah you don't get instructions.
Post Posted: Mon Feb 28, 2011 1:26 am
Before it was put back into the carrier and ready to be put back into the housing.
Post Posted: Mon Feb 28, 2011 1:35 am
put the 2nd & 4th photo's together & that's pretty much how it would look. :wink:
i wonder if there is a difference between the 10 & 12 bolt carriers & that is why it needed machining.
SiKiD is running one in the rear of his LWB, not sure if it's 10 or 12 bolt though.
Post Posted: Mon Feb 28, 2011 3:16 am
Just that I wanted to see what's involved because I just ordered one. :D
Vehicle: 75 Cruiser
Post Posted: Mon Feb 28, 2011 3:35 am
atari4x4]i wonder if there is a difference between the 10 & 12 bolt carriers & that is why it needed machining..[/quote]
yer i thought it was weird that it didn't fit and thought mine must be different to normal.
It's pretty easy, open the diff up and take everything out. To get the big pins out you need to tap out the little pins that go through the big pins, very technical terms there.
pics help...
Post Posted: Mon Feb 28, 2011 6:01 am
Is the X-90 diff similar/same as a Vit/GV? Or is it some oddball one, hence no fit?
Users browsing this forum: No registered users and 58 guests
