It is currently Fri Nov 13, 2026 4:59 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page 1, 2  Next
Vehicle: LWB Sierra & XL7
Post Posted: Sat Mar 12, 2011 6:28 am
First off to do this, You will need the correct grade gear oil and a 3/8" square drive bit, I just use a 3/8" sliding T bar or ratchet and a Drain pan, You will need about 2L of oil. Buy a 5L bottle, you will be saving money especially if you replace it reguarly or are doing the front diff at the same time.
Chock the front wheels and jack the car up on some stands.
The top hole is to fill it, The bottom hole is to drain.
Place your drain pan under the diff. Remove the top plug first, It would be a pain if you drain the oil first then realising you can't undo the plug to fill it back up.
Once all the oil is drained, put the drain plug back in and tighten.
If you bought a 1L bottle, they usually have a spout that pulls out to help pouring. Alternatively you can use a funnel with a length of hose. Pour the oil into the filler hole until it starts to come through the hole. Then replace the plug and tighten.
I use an oil syringe/pump. It makes filling the gearbox and transfer case much easier. Put the hose into the bottle and pull on the lever to fill, push the lever to release.
Make sure you dispose of your oil thoughtfully, You can dump your oil at most mechanic workshops or at your local council tip in the designated area. Don't put it into the used bottle and place it in the bin which will end up as landfill, the bottle may brake and spill oil into the ground!! That will make baby jesus cry and Chuck Norris will hunt you down for revenge.
Post Posted: Sat Mar 12, 2011 6:32 am
3/8" Drive, not 3/4 :)
I did mine today and thought I should take pics :)
I used one of these
http://www.stm.net.au/index.cfm?fuseact ... oductID=57
made it real easy
Post Posted: Sat Mar 12, 2011 6:38 am
fixed.. I hate imperial sizing
'92 Vitara & Camper trailer
Vehicle: 2018 DMAX
Post Posted: Sat Mar 12, 2011 7:14 am
I used one of these
made it real easy
8O
Post Posted: Sat Mar 12, 2011 7:20 am
nice work :)
screwdriver's on ur head impale DropBears :)
Post Posted: Sat Mar 12, 2011 9:04 am
I used one of these
http://www.stm.net.au/index.cfm?fuseaction=viewItemDetail&productID=57
made it real easy
I bought one of these from Ripco a couple of years ago,
Best $30 I ever spent, but if I ever upgrade, I'll be buying
One of those ones that you plug your air compressor into.
If your not breaking shit, try harder!!!
Post Posted: Sat Mar 12, 2011 9:31 am
http://i1182.photobucket.com/albums/x45 ... 1299927523
Post Posted: Sat Mar 12, 2011 9:35 am
my simple oil pump^^^^^^^^
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Sat Mar 12, 2011 7:03 pm
10mm sqaue bit actually.
Whilst the 3/8 may work perfectly fine the majority of the time. If you get one that's really tight, the slightly larger 10mm will fit better and won't slip rounding out the bolt head.
Post Posted: Sat Mar 12, 2011 9:49 pm
Thank you sir - this is the one I use.
http://cgi.ebay.com/ebaymotors/8mm-10mm-Square-Drain-Fill-Plug-Sockets-Ford-Volvo-Saab-_W0QQcmdZViewItemQQhashZitem5642ae499bQQitemZ370485905819QQptZMotorsQ5fAutomotiveQ5fTools
Post Posted: Sun Mar 13, 2011 9:23 am
i bought some 10mm key steel the other day for this exact job. 3/8 bit slips at times.
my pump is a fountain squeezy sauce bottle.makes a slow but clean job :lol:
Vehicle: Daisy
Post Posted: Sun Mar 13, 2011 10:28 am
Holy crap, all this talk of oil pumps, I've just been using the penrite oil with the pull up spout, a bit of hose (just slipped over the spout) and squeeze the bottle...
Takes a while though, especially when we do both diffs, transfer and transmission...
I might rig up some kind of pump or buy one for when I go to do the transfer case oil for the 1000km change after my new gears.
Post Posted: Mon Mar 14, 2011 8:25 pm
I used one of these
made it real easy
8O
You should throw out your dirty bong water.
Post Posted: Mon Mar 14, 2011 9:22 pm
x2 on the 10mm bit
the previous owner of my jimny sent it into the shop to get the oil changed and they ended up making the square, not so squareish.
Post Posted: Tue Mar 15, 2011 2:09 am
You can get away with that on the diffs, where there is room to get the bottle over the fill hole - but on the transmission & transfer case it's a different story, the pump is a couple of bucks, makes the job easier and usually a lot less messy.
Location: Southside Brisbane- the best side of the river
Vehicle: Shitbox
Post Posted: Sun Jun 05, 2011 3:52 am
I cant seem to find it anywhere how many litres does each diff take?
Post Posted: Sun Jun 05, 2011 4:09 am
Sierra is 2.0l front 1.5l back, transfer 0.8l, gearbox 1.3l I think. :lol:
Vehicle: Shitbox
Post Posted: Sun Jun 05, 2011 4:30 am
Thanks mate
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Jun 06, 2011 1:24 am
For those who are reading this because they dont know how to change thier diff oil, most of them who wont do do it an are reading on how to do it the first time wont want to make or buy a pump, so this way is even easier.
Put some hose pipe on the end of a funnel.
I dont have a pic, but Im sure many of you can visualise a piece of garden hose, about a meter long, on the end of a funnel.
Feed it down though the engine bay for the front, or the RH wheel well for the rear. For the Gearbox or Transfer case unscrew the gearbox lever boot and feed it though there.
Enjoy
Post Posted: Mon Jun 06, 2011 7:52 am
But thanks for highlighting the cheaper alternative. :)
Vehicle: 1995 Sierra 1.3
Post Posted: Thu Jun 09, 2011 2:31 pm
Vehicle: Daisy
Post Posted: Thu Jun 09, 2011 7:57 pm
Enjoy
This is what I was saying I do, I don't use garden hose or a funnel, just some left over irrigation pipe (really small stuff for the garden...) and put it over the spout on the bottle.
If you have a body lift you can get to everything from the sides and the diffs just from the front and black.
Post Posted: Thu Jun 09, 2011 8:33 pm
Can you use LSD oil in open diffs?
Got an emergency oil change to do before a trip and only have LSD left.
Post Posted: Fri Jun 10, 2011 12:13 am
does anyone use any type of sealant on the drain/fill plugs before you pop them back on? for diffs/box/trans
thanks
Kelvin .: White 2004 Jimny JLX :.
Post Posted: Fri Jun 10, 2011 12:16 am
Nope.
Post Posted: Fri Jun 10, 2011 7:45 am
thanks
No sealant or gasket goo is required.
But If for some reason you do need to use it, use grey sealant.
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Fri Jun 24, 2011 11:08 pm
How many litres of oil do I need for a vit transfer and diffs?
Post Posted: Fri Jun 24, 2011 11:50 pm
gear box 1.5ltr's
transfer 1.7ltr's
front diff 1.0 ltr
rear diff 2.2ltrs
info from here
http://www.suzukiinfo.com/
 Profile YIM
Post Posted: Sat Jun 25, 2011 12:04 am
awesome thanks.
Post Posted: Wed Sep 21, 2011 3:27 am
What oil do I use. It's for a Sierra if it helps:/?
What grade and what's it called? Thanks
Users browsing this forum: No registered users and 33 guests
