It is currently Thu Aug 22, 2019 10:11 am
Post new topic Reply to topic  [ 133 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Post Posted: Thu Jun 19, 2008 9:39 pm
hey moose can you please post a pic of your beast flexed up.. i want to see how the rear compares to mine..
my ride dont flex for shit cus the shocks a limited,.. they looked maxed out when sitting flat.. heheh..
here is a pic of mine..
my 35s are almost inline with the sliders.. i want then to go far beyond them..
if were to get slightly longer springs and all i get is the same sought of flex as 83zook, (dont get me wrong, thats some good shit) i dont see the point of all the stuff around.. i might as well just remove 1 leaf.. my rear shakles angel is between moos and 83zook,
spoa, lux diffs, 2inch suspension, 2inch body, 1.6
Vehicle: Clown Car..
Post Posted: Thu Jun 19, 2008 11:05 pm
moose's is currently off the road.. but rig looks like
oops wrong moose..
no 'flex' shots as such.. that i have.. but basic idea is there..
moose runs on 33's the 35's on yours look like MASSIVE overkill on the zuki...
Post Posted: Thu Jun 19, 2008 11:35 pm
yhe i heard about that ^^^^^^ thats goto suck.. i thought he would have pic of it flexing befor acca. yhe i would of chosen to run 33's if i built it.. but mhe.. it was on there wen i got it and its engineered for it.. but it will go over bigger obstacles easier :twisted: ..
but who knows,, might down grade to 33s.. saves me buying t/case gears. :wink:
Vehicle: '92 Sierra
Post Posted: Fri Jun 20, 2008 1:19 am
Moose, with the schackle reversal did you find the front wheels would drop off an obstacle and the shackles would get hung up? I was under my rig today and looking at how fast the chassis drops down where the spring hanger is. I figured with an SR the schackles would be damn low. I even considered puting ths schackle hanger tube through the chassis like a hilux but thats not exactly as easily reversible hehe.
Post Posted: Fri Jun 20, 2008 4:11 am
I agree especially considering you can actually see it rubbing on the front and the way to short wheelbase for 35's. How steep is your driveway? Cause that thing would flip on mine...
Post Posted: Fri Jun 20, 2008 4:20 am
Mooses SR looks fully custom with long leaves that mount further back on the chassis than the normal sprin hanger point. My calmini kit uses the normal spring hanger location to hang the shackle from. It's only a smallish shackle though not much longer than stock if at all. I don't find it to be a problem at all and I often drop off steep ledges. I actually love doing it cause I know I can with the awsome approach and departure angle zooks have but alot of my mates bigger trucks can't with alot more tyre than me.
Post Posted: Fri Jun 20, 2008 3:11 pm
like i said in the previous post, its how i got it..
so i might as well use it right..
as for the wheel base.. ill be stretching its out once i get the car back from the shop... ill be doing the RUF and 323s in the rear.. in that pic it actually didn't rub that much.. it just skimmed it plus the wheel was turned..
iv had no troubles doing some decent hill climbs.. it was actually a good thing i had the 35s cus on the top of the hill was a point.. i would of bellied out..
there are a lot of ppl running 35s on there zooks.. its not a bad thing champ.. it may be prone to tipping a lil more than one that has stock height and wheels, but hey you still hear about them tipping, TRUE.. even ppls with 80series, the can still put them on there sides..
it comes down to how careful you are and which path on the track you wish to use.. if you are sure you are going to tip on a certain path then DONT DO IT.. or build your self a exo cage,, thats another thing on my to do list
Post Posted: Fri Jun 20, 2008 3:23 pm
:oops: :oops:
believe it or not , i dont have any pics of the rear flexing !!!
only this 1 from behind !!
(top shock mounts on top of x-member & inboarded slightly !! rear explorer shocks !!)
if all else fails , back up & hit it again !!!!!
Post Posted: Fri Jun 20, 2008 3:29 pm
with the front shackles , they did cop a bit of scrapping , but never enuff to get stuck , with the weight of a zook , its not really a big issue !!
also thought of going through the chassis , like a lux ,
see how it looks in a couple of weeks , on stage 2 !!
(also i was still running standard shock mounts !!) :D
Post Posted: Fri Jun 20, 2008 3:32 pm
heres mine on 35,s !!
Post Posted: Fri Jun 20, 2008 5:53 pm
moose wrote:
:oops: :oops:
hey moose, correct me if im wrong but in this pic are your running SUA ..
what kind of lift have you done to your rig..
Post Posted: Fri Jun 20, 2008 5:55 pm
8O what made you change from 35s to 33s,
Vehicle: SJ51WT.FZJ105R.XKWags
Post Posted: Fri Jun 20, 2008 11:10 pm
ok been trying the rear mazda 323 springs in the rear via trial and error.
These pics it sits tooo low. stock mazda spring, with 15mm wheelbase ext.
These pics are with mazda main. 2" mid, 2"semimid (smaller with clamps), Then mazda bottom. (cant really see, small..)
Now im getting a funny warp in the spring because of the 2" springs in the middle...
Should i just cut the main 2" spring with the loops for shackles not on the car, so it sits out more so the pivot point of the spring is off the other leaf as shown?
I confused on what to do... rises up to stock bumpstop, But does not seem to drop 'without short shocks' more then before either on a ramp up a drain canal...
OR, Sorry.. Should i have gone Mazda main, 2" main with loops cut off, 2"semi and chuck in a mazda one on bottom. I want it soft but with lift...
Hard to explain.
Post Posted: Sat Jun 21, 2008 2:49 am
you need a 2nd leaf as long as the main without the bush endsso it will support the vehicles weight.
Also by moving your front mount bolt hole forward some it will take some angle out of the shackle and also give it some lift
Post Posted: Sat Jun 21, 2008 2:54 am
Im thinking i might have to find another main and cut for a 2nd or use my 2" main cut...Which i dont really want to cos if this doesnt work i cant go back to the normal 2"springs.. :?
Also if i move the springs forward, it will upset the location already.... The stock 323 location + 15mm longer wheelbase means its almost right on the edge of the diff plate.. Dont want to redrill the springs, scared of snapping them :?
Post Posted: Sat Jun 21, 2008 3:24 am
Greg wrote:
2wd ISUZU ute are a great fit
Rodeo ute?
92 WT softback ute, twin lockrights, 3.9 diffs, S1
Vehicle: 75 Cruiser
Post Posted: Sat Jun 21, 2008 3:30 am
swb on 35s is what i call a flipper, get a good cage, harness and helmet :lol:
Vehicle: '92 Sierra
Post Posted: Sat Jun 21, 2008 5:36 am
LOL yeah, don't want your tyres to rub together under compression...."it's not about how big your tyres are, its how you use them without doing an endo"
Post Posted: Sat Jun 21, 2008 1:23 pm
Norm , yep still SPUA !!! :D 8) :D
Post Posted: Sat Jun 21, 2008 11:46 pm
so moose what made you go down to 33's from 35s..
if i were do go smaller i would remove my BL, which looks likea pain in the ass
Post Posted: Sun Jun 22, 2008 11:19 am
my spring set-up was so flat , so nullabor looked like mt kosi ! , i ran a 4" body lift !!! 8O
not that you would notice !!!
MK 2 is NO BODY LIFT !!!! :twisted: :twisted: :twisted: :twisted: :twisted:
Post Posted: Mon Jun 23, 2008 12:41 am
the first pic was my last set up from xmas time.
and the next is as its is now, sorry for the nite pic but its all i have atm
Post Posted: Mon Jun 23, 2008 12:44 am
after
Post Posted: Mon Jun 23, 2008 1:20 am
11_evl wrote:
after
whats your set up on this befor and now..
nice flex BTW
Post Posted: Mon Jun 23, 2008 1:26 am
now is coils, 3 link with panhard and 32" simex which measure 33"
before was mazda springs, drop down shackles, inverted rancho shocks and 31s.
both pics wernt at FULL flex
Post Posted: Mon Jun 23, 2008 2:30 am
Have you got a pic of how your car sat with just the mazda leafs?
And what assortment of leaves did you have? Meaning what springs in your packs etc?
Post Posted: Mon Jun 23, 2008 2:39 am
did you say drop shackles 8O 8O Thats cheating. Got any real flex pics without the drop shackle cheating
Post Posted: Mon Jun 23, 2008 2:49 am
because the mazda springs were very long i had to do someting to make them work, so other than a chassic extension, the drop was the way to go.
i will post a pic tomorrow
Post Posted: Mon Jun 23, 2008 11:00 am
b4t, do you think nitrous is cheating, or turbo charging???
ill do whateva it takes to win the race :D and drive some hard tracks along the way..
my last setup was rear:
spoa mazda springs, 4 leafs total, they measured 45"..
front was full RUF with 2"lifted springs spua, drop shackles front and rear
below pic was taken after everything settled in on old setup..
next pic is my REAL flex pic, just for you b4t
Post Posted: Wed Jun 25, 2008 3:05 am
I have now made up my decision!!!! :lol:
I have the stock mazda 323 rears in the back.
I have the stock suzy sierra rears up front.
The rear shackle angle is like 1st pic,
Then front shackle angle is abit more vertical, i said abit...
Both sets of spring packs make it lower then before, Bit like the 1st pic up top, but all round.
The rear diff is drilled 35mm back = 15mm extra wheelbase
The front diff is stock rear spring location = 30mm extra wheelbase(on my springs)
I now need new longer brake lines. Yet to sort out how much longer
And then via a huge flex test (Crossing my fingers it flexes hardcore :twisted: ) I will need to remount the shockmounts higher to suit the dropage. Front and back
See how we go now.. :roll:
Users browsing this forum: No registered users and 1 guest
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
