It is currently Wed Jan 17, 2018 7:24 am
Post new topic Reply to topic  [ 435 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15
Vehicle: 2011 Jimny
Post Posted: Mon Oct 09, 2017 11:39 am
Just did the 13->1.5 vvt swap on my Jimny. Was fairly straightforward, just had to swap almost everything from one motor to the other. Ended up taking me and a couple mates ~14-16 hours total at a leisurely pace with two cartons of jacks.
2011 jimny, 30s, china locker, swift 1.5, pink playboy seat covers
Vehicle: 2008 Suzuki Jimny
Post Posted: Wed Oct 18, 2017 6:45 am
Hi all
Has anyone here fitted an aftermarket ECU on their VVT Jimny transplants yet? piggyback or standalone? I'm off to have a look at an M18A for my Jimny this week, if I go ahead with it I'll be fairly keen to fit an ecu and get it properly tuned, just want as much info as I can get before I fork out for the bits.
There is surprisingly little info to be found via google library regarding ecu upgrades for the VVT Jimny. I've had a look at the Haltech software and there's no base maps in the standard library for an M18A. There is trigger settings for the M16A but it doesn't say if it's VVT or not.
I've contacted a Haltech dealer in Vic requesting a recommendation but am yet to hear back.
Thanks
Vehicle: Suzuki Jimny Jlx 2003
Post Posted: Wed Nov 15, 2017 11:19 pm
Hey all,
Ive read this post multiple times now, im looking at dropping a M15A in soon, its out of a 2005 cruze, non vvt conversion.
I get that i use M13A exhaust, starter, power steering, air con, all pullys, alternator, fly wheel, clutch, fuel rail ect.
M15A injectors
Looks like change rocker cover, or drill out an move dipstick to.
Only thing im unsure about....
What about the intake manifold an throttle body, M15 or M13?
Vehicle: Jimny
Post Posted: Mon Dec 04, 2017 9:26 pm
Awinspired wrote:
Hi all
Thanks
I am a firm believer that you MUST fit a piggy back system at the least to do fueling and timing.
2009 Zook Jimny Sport
2inch Jimnybits lift kit
AVO adjustable shocks
Adjustable panhard rods
235/75r15 Kumho KL51
Ex: 2010 Suk Grand Vitara
Ex: Toyota Yaris TS
Build Thread: http://www.4x4community.co.za/forum/...ead?highlight=
Vehicle: 2011 Jimny
Post Posted: Tue Dec 05, 2017 2:21 pm
Chechan-Rebel wrote:
Hey all,
M15A injectors
M15 manifold from the swift wont fit in a jimny. the swift tb is the same size. Probably very similar outcomes for the cruze.
Post Posted: Tue Dec 05, 2017 3:40 pm
Hey all,
M15A injectors
Manifold isnt off a swift, its out of a cruze, manifolds look identical, has all the vacumes...... only difference i can see is jimny one has #21 on it, cruze has #25
Vehicle: Moke
Post Posted: Wed Dec 06, 2017 2:41 pm
Did a M15 hi-comp swap a couple weeks ago, running pretty sweet but really feeling like its restricted.
The TB is the same size so need at least an M16 TB... Anyone have a spare laying around???
Exhaust could probably do with some extractors and a decent free flowing 2" or there abouts.
But anyways, couldn't of started this without the thread, a case of beer and a mate with a zook.
Maybe I should start a build thread...
Vehicle: Jimny m13
Post Posted: Sun Dec 10, 2017 12:55 pm
Hi, wich ECU did you use ?
Vehicle: 2011 Jimny
Post Posted: Mon Dec 11, 2017 10:38 am
Stock jimny m13 with m15 injectors
Vehicle: jimny
Post Posted: Mon Dec 11, 2017 9:14 pm
Back to an old topic - injectors. The liana yellow injectors I believe are 254cc or there abouts, their denso part number is 195500-4630. Masda mx5 2001 to 2005 1.8L have a purple injector that has the same moulding and plug fitting and seals etc denso part number 195500-4060 they are 265cc. Would this solve the leaning out problem at top end power? (Of course would be richer down low)
Post Posted: Wed Dec 13, 2017 1:04 pm
Motors here, extractors, heavy duty clutch been here 6 months still sitting in box, gaskets an all other bits are here, tearing M13A out tomorrow. Last thing to do is get flywheel ground. Then put it all back together.
One thing im having trouble with is finding the fuel pump relay, its a 2003 model jimny, any one know location?
Post Posted: Fri Dec 15, 2017 8:43 pm
All good found relay, motors ripped out, got flywheel ground...... time to put it all back together an see if it runs.
Post Posted: Sun Dec 17, 2017 2:22 pm
Rivar wrote:
I think I mentioned it in the private message, that the m16 cams have bigger lift and duration than the m13.
1.5mm on intake and 1mm on exhaust. The exhaust cam is a direct drop in. The intake needs a bit of fine tuning...
On the end of the m16 intake cam is another tooth gear for the cam angel sensor pickup. This needs to be swapped from the m13 cam... Then when doing timing, the cam has to be retarded by 1 tooth on the timing marks to work...
My final dyno figures are 85kw and 145nm at flywheel.
I have not done the same work on the cams as Rivar. I am running the standard M13A cams and intake with M13A
injectors, I have installed a complete exhaust with ceramic coated headers, and euro 4 cat.
On the dyno I have achieved 82.5kW and 149nm at the flywheel.
Old mate at Newcastle dyno centre was not worried in the slightest about the fuel delivery at higher revs.
Post Posted: Mon Dec 18, 2017 11:53 am
hmmmm....... 1st start up, not to bad..... got 2 fuel injectors leaking, not sure why..... will put new o rings on an re-check.
Post Posted: Sat Dec 23, 2017 10:06 pm
So im running M15A 2005,
M15A manifold an injectors.....new extractors, lightened flywheel, heavy duty clutch, bigger leads, new plugs, fresh oil, had a new water pump here as well, new manifold gasket an exhaust an rocker, ended up swapping rockers an dipstick, also got rebuild kits for the fuel injectors.
Idles perfect, no engine light, no overheating. done about 300 ks allready, also towed 3x 2 tonne loads of wood. Goes wicked now, hills that use to be 2nd are now 3rd gear, 3rds are 4th, an 4ths are 5th.
Just want to thank everyone who put together this guide.
Users browsing this forum: No registered users and 3 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
