It is currently Fri Nov 13, 2026 5:21 pm
Post Posted: Wed Dec 05, 2012 11:33 am
Just wanted to get these up for people to have easy access to if they are installing transfer gears in a Vitara. There are some subtle differences between these instructions and my experience, but they are a very good starting point and much easier to read than the tiny black and white images you get with the gear kit.
These only cover installing the new gears. For a full rebuild you have to split the other side of the case as well, but once you get this far in you'll figure out the rest.
Thanks to christover originally, and shandy for sending them to me.
[/quote]
Post Posted: Wed Dec 05, 2012 7:25 pm
Made a pdf if it helps http://sdrv.ms/TESAjH
I found small differences in the instructions that came with the gears, too.
But both were a good guide, even though I wandered away from them at times.
Found originals on Zukiworld, but seem to be missing now. Glad I saved them.
Vehicle: Vit swb 95
Post Posted: Tue Feb 05, 2013 4:52 pm
so i decided to start pulling my case apart,
so far i have found it quite easy but now im stuck...
im on picture number 11
Ive done everything before it, but it will not come out.... is there something im missing???
Post Posted: Tue Feb 05, 2013 4:59 pm
maybe end is a bit burred, or something sticking, mine fell out easily
Vehicle: Vit swb 95
Post Posted: Tue Feb 05, 2013 5:08 pm
it feels the same as if the yoke and pin are still in :/
Post Posted: Tue Feb 05, 2013 5:17 pm
maybe you missed a detent ball or spring
Vehicle: Vit swb 95
Post Posted: Tue Feb 05, 2013 5:25 pm
got a total 4 balls and springs out? does that seem right :S i checked ill of them :/
Vehicle: Vit swb 95
Post Posted: Tue Feb 05, 2013 5:35 pm
sounds right.
try pushing it back in and out, same time as slightly twisting back n forth
Vehicle: Vit swb 95
Post Posted: Tue Feb 05, 2013 7:47 pm
Tried, no luck :/
Post Posted: Tue Feb 05, 2013 7:53 pm
Maybe box is still in gear, putting pressure on it?
Did you remove stick when in neutral? that could be an issue..maybe
Vehicle: Vit swb 95
Post Posted: Tue Feb 05, 2013 8:32 pm
Dunno it was someone else's :/
Post Posted: Tue Feb 05, 2013 9:46 pm
take a break, look at it on a fresh day, it may fall out easily next try
Post Posted: Tue Feb 05, 2013 10:22 pm
Mine practically fell out, to the point where I didn't get a chance to mark the alignment :roll:
2 switches (only one has a ball)
2 rod locating springs/balls
1 select lever spring/ball
Can you get something onto the end of it and give it a tap that way?
Vehicle: Vit swb 95
Post Posted: Wed Feb 06, 2013 7:02 am
So i got the 4 balls out, thats fine...
Yeah tapped the end and it doesnt budge
mark the alignment?? what do i have to do there?
Doesnt say anything on these instructions
Post Posted: Wed Feb 06, 2013 8:41 pm
Nuthin' as it turns out. One of the sets of destructions I had said to mark the gear and collar so they went back in the same way. Either I got ridiculously lucky and fluked it back in the same or it doesn't matter.
Have you got a gear puller you could get onto the shift fork? Weird that it won't slide given that it's designed to... do you know for sure the case was OK when it was removed from the seller's car?
Vehicle: Vit swb 95
Post Posted: Thu Feb 07, 2013 6:49 am
He said it was working..
I got it out, but i had to use a screw driver and hammer to hit it out
And theres no way its just going to "Slide" back in... everything within the case look in good condition and its clean as,
But guessing this shaft could be buggered???
Users browsing this forum: No registered users and 35 guests
