It is currently Sat Sep 19, 2026 1:36 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2
Post Posted: Sun May 20, 2012 1:41 am
55W/12v=4.58a. Since 20 Amps is over 4 times 4.58, it's ample.
Post Posted: Sun May 20, 2012 7:25 am
i would use two 20amp relays as using something at 95% max capacity would limit its reliability.
or just get a good relay to start with, i use 70amp jobbies and real cable
Vehicle: chick magnet coily
Post Posted: Sun May 20, 2012 7:43 am
i have a spare 80A relay and 4mm cable will it be ok?
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Sun May 20, 2012 8:00 am
is it 4mm2 cable or just that crap on a roll from stupid cheap.
good 4mm2 cable would be around 30amp but the 4mm stuff from shit shops would be lucky to be 10 amp.
Post Posted: Sun May 20, 2012 3:17 pm
its the stuff from super cheap
where would you recomend buying cable from
Post Posted: Sun May 20, 2012 3:42 pm
Springers (I think that's what they are called) @ lawnton do a lot of 12v stuff. They are reasonably priced and great to deal with
Post Posted: Sun May 20, 2012 3:48 pm
Ashdown Ingram are great auto electrical suppliers also
Post Posted: Sun May 20, 2012 5:08 pm
I was a bit drunk when I read and responded so I didn't take into account quantity required.
3 x 55W = 165W
165W/12v=13.75A. Still well within spec of a 20A relay.
I'd check out Jaycar or Altronics if you have one nearby. They both have online websites as well.I was a bit drunk when I read and responded
Are we talking 4mm conductor or 4mm OD of cable? 4mm copper would be overkill. Shep is right in that 4mm OD could vary in the actual amount of copper considerably. More insulation = less copper = less current capacity.
Post Posted: Sun May 20, 2012 5:16 pm
Single 4mm2 at the usual 1.5m length for a bar mounted spotlight is .2v drop, I think that could be done better
Rather using your supercheap 4mm cable (Usually this is 1.84mm2) but with a single run per light, so 3 runs, will give you 0.017v drop, much much better
Though I dont know if HID lights are as sensitive to voltage drop as halogen and really youll get more drop in the entire system from bad joints and poor crimps
Post Posted: Sun May 20, 2012 6:09 pm
thanks ill drop into springers after work one day as i work in at brendale
Post Posted: Sun May 20, 2012 10:26 pm
Brendale... Go to AME Products. They carry an extensive range of automotive electrical. Not on show, all by catalog. Just tell em what you are doing and what youy think you want.
Post Posted: Mon May 21, 2012 4:22 am
where is AME products i am just off southpine road near IPLEX
Post Posted: Mon May 21, 2012 5:08 am
Let your fingers do the walking on where AME are.
Post Posted: Mon May 21, 2012 7:30 am
And I get in trouble for suggesting Google :roll:
:thefinger:
Post Posted: Mon May 21, 2012 7:53 am
10 sec work :wink:
http://www.ameproducts.com.au/Contact-Us-pg10844.html
Would you like me to call them now for you fully sick and then go pick up. :thefinger:
Post Posted: Mon May 21, 2012 12:43 pm
I need some things picked up too Bruce, I'll pm you the list.....
Post Posted: Mon May 21, 2012 3:20 pm
Ha ha ive sent Bruce there before :rofl:
Post Posted: Mon May 21, 2012 4:49 pm
Yes, yes you have Royce. They have moved from the last time you sent me there. They must be at least an extra 3 mins drive now :-)
Post Posted: Mon May 21, 2012 5:45 pm
thanks
Post Posted: Mon May 21, 2012 5:59 pm
How did you get on fsc? Did they have what you wanted?
Post Posted: Mon May 21, 2012 9:49 pm
just use some 2.5 or 4.5mm tps ;)
Vehicle: vits
Post Posted: Tue May 22, 2012 9:08 pm
This will work but is not ideal..... this type of cable doesn't handle vibration too well and can fatigue and break when used in cars.
Vehicle: 1.3 Tin Top
Post Posted: Thu May 24, 2012 8:02 pm
HID ballasts are not voltage sensitive. the good quality ones will run between 9-32v
Vehicle: '94 suzuki maruti
Post Posted: Sat Jun 02, 2012 7:31 am
AFAIK, they only sell bulk... I just went to them and purchased a 30m roll of 6mm wire. i think thats good for 50Amps?? costs $60... i used it for headlight relay upgrade and spotties (55W HIDs) and works excellent. cant remember figures but it was bugger all voltage drop.
Users browsing this forum: No registered users and 39 guests
