It is currently Tue Sep 22, 2026 4:49 am
Vehicle: Suzuki Jimny
Post Posted: Thu Feb 18, 2016 9:59 am
Hi I have searched throughout the web looking for a tutorial in regards to swapping front and rear 4.3 diffs from a VVT 2005+ into a 98 Jimny so I can return my gearing back to standard after fitting bigger tyres.
How easy is this? Are they a straight bolt off bolt on or is there modification of the diff housing required?
Thanks in advance.
Post Posted: Thu Feb 18, 2016 10:10 am
if you buy whole diffs they are bolt in
Post Posted: Thu Feb 18, 2016 11:36 am
Thanks for the reply, would you know if the centres are a straight swap?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Feb 18, 2016 12:27 pm
keep in mind if you dont have a full floating conversion in the rear end the axles dont just slide out.
Post Posted: Thu Feb 18, 2016 1:40 pm
So it has to be a whole diff swap and not just the centres?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Feb 18, 2016 1:58 pm
pretty sure the only difference is the R&P.
Post Posted: Thu Feb 18, 2016 2:07 pm
Thank you, I will source some 4.3 centres and make the switch
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Feb 18, 2016 2:36 pm
i have a full housing and 4.3 diff for sale FYI. and a full float and disk conversion kit.
viewtopic.php?f=7&t=51372
Users browsing this forum: No registered users and 50 guests
