| Author |
Message |
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Mon Apr 24, 2017 10:04 am |
Just fell into a bit of a washout taking a pump down to the creek, and it started clunking.
Please tell me I can just put a bolt through it..gotta go out for a while so will just twitch it for now.
tar
bye
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Mon Apr 24, 2017 2:14 pm |
bolt/ratchet strap, Even a new mount would help
bYe
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Mon Apr 24, 2017 3:20 pm |
+1 on new mount.
Bye
_________________ 31zook wrote: Makes me want something similar
bumstein
 Posted: Mon Apr 24, 2017 3:25 pm |
What's happened to the mount? Has it snapped? Is it the bracket or the rubber mount?
On one of my old jalopys I got away with no mount for a while. But it's not ideal. Get one as soon as you can
bumstein
 Posted: Mon Apr 24, 2017 3:26 pm |
cairns27
 Posted: Mon Apr 24, 2017 4:30 pm |
Yeah I'll mainly park up till I get a new one. It was the LHS one with steel glued to the rubber.
thanks bye
cairns27
 Posted: Fri Apr 28, 2017 5:42 pm |
I got a new t'fer mount from FNQ Filters and Spares in Mareeba, part Transgold TEM0235, and the studs were 3 or4 ml longer. I was about to get a knife blade to it, and decided to get a hammer first, and it went in. Will be a drama replacing it next time, I wish now I had cut the studs.
bye
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Fri Apr 28, 2017 5:44 pm |
Which you will need to in 5...4...3....
Only genuine Bridgestone mounts last.
cairns27
 Posted: Fri Apr 28, 2017 5:47 pm |
It cost $38.00, I's only the second time I've broken it in ten years.
bye
Gwagensteve
 Posted: Fri Apr 28, 2017 6:22 pm |
So the other mounts are also non genuine?
cairns27
 Posted: Sat Apr 29, 2017 6:23 am |
Can't remember, but a friend rebuilt the t'fer box for a few years ago. Des at Briktec motors on Supply Road, Edmonton, has also looked at it. The handbrake drum almost touches the chasis. Neither thought the bracket was bent, and it has not vibration. Des is the Suzisport agent, and does know a lot about Suzukis
bye
