It is currently Wed Sep 23, 2026 7:43 am
Post Posted: Mon May 01, 2017 3:05 pm
I noticed liquid on the inside of the rear wheel, fiqured it would be the wheel cylinder, pulled the hub off, but shit over everything, so I just degreased it, and put it back together. Drove out to the bitumin, and when back and forward, jumping on the brakes, hoping to adjust them up. Seemed to work. Was going to look for the leak in the morning, the cylinder was moist under the end caps. Fuck me the thing won't idle now, redlines easy.
What can be wrong ???? I played with both idle screws, no difference. Vac hoses seem good.
Thanking you in anticipation .
bye
Post Posted: Mon May 01, 2017 4:02 pm
Idle jet blocked. Need to pull apart and clean.
Leak will either be axle seal or slave cylinder.
Sayonara.
Post Posted: Mon May 01, 2017 4:26 pm
Yeah, I haven't checked the diff level yet. I got a filter before the carby too. Pulling the carby apart is beyond me.
Could something really got in there.
The leak is the least of my problem, I'll drive it like this till I see what's wrong.
bye
Post Posted: Mon May 01, 2017 4:43 pm
Checking the jets is pretty easy.
On the float bowl there's two large brass plugs. Undo them and get a flat head screw driver in to undo the jets. Might need to lift the float a little (undo one jet while lifting the float wth a screw driver in the other hole).
Easier than it sounds!!
Yes they get blocked.
Change all your fuel filters too
Post Posted: Tue May 02, 2017 5:25 pm
Like a bought one again. Glad I didn't f*#k with the carby, it fixed itself. tar
bye
Users browsing this forum: No registered users and 42 guests
