| Author |
Message |
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Wed Jul 12, 2017 3:14 pm |
So the tell tale has just started to leak, maybe 200mls @ 100K's. Will it be a catastrophic failure, or just get gradually worse ?.
tar
bye
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Thu Jul 13, 2017 8:32 pm |
Fix it before it does get worse.
Bye
bumstein
 Posted: Thu Jul 13, 2017 10:50 pm |
It's not a hard job.. replace your timing belt while your at it
Bye
Bammo
Vehicle: Holden Drover '85 NT 1,3
 Posted: Fri Jul 14, 2017 2:15 pm |
bumstein wrote: It's not a hard job.. replace your timing belt while your at it
Bye Definitely not hard - took most of a day when I did the first water pump / timing belt combo mostly because I was nervous and kept worrying that it was harder than it actually is. I reckon 45 minutes from start to finish now! You really cant stuff it up provided you align the timing belt properly. I had assumed it would be really twitchy and hard to get perfect and it isn't, its very tractor-like and is either correct or not and pretty easy to tell which is which. A small torque wrench is handy for when you do up the timing tensioner pulley and the cover bolts but if you have a calibrated wrist you can make do.
cairns27
 Posted: Sun Jul 16, 2017 4:03 am |
Yeah, I've read on here before that it's not a big job, but it took me four hours to replace a uni the other day, in the end I got the fitter around, and used the old circlips. This water pump is not that old, 10 m- 20,000 K's, done 5yrs ago, I still got the old pump, and have been mulling over using it. It won't need timing chain or seal, as this was all done last time. I think I'll pull it apart today, and go into Mareeba, and if they've good one there, I'll buy it, if not the old but goodie will just go in.
tar
bye
cairns27
 Posted: Mon Jul 17, 2017 3:57 am |
I just put the one I replaced 5yrs ago back in. Everything looked good in there. Took 5hrs, but most of that time was spent removing a bolt I broke off, and finding and cutting a bolt that would fit. Had one minor heart attack, after putting the timing belt back on, I fired it up to see if all was well. When I looked at the belt, the top pulley mark and the belt mark were out, then I realized I'd put a mark on the adjuster and belt too. I'll buy a new water pump when I'm next in Cairns, I'll just drive on Karma till then. Maybe 2hrs next time.
Thanks
bye
bumstein
 Posted: Mon Jul 17, 2017 10:15 pm |
The motors aren't interference motors or so I'm lead to believe so even if you get the timing wrong it shouldn't cause damage (big emphasis on 'shouldn't') but just won't run well if at all. You can't stuff it up really
BlueSuzy
 Posted: Tue Jul 18, 2017 5:09 pm |
greenzook89
Joined: Sun Sep 06, 2009 11:30 pm Posts: 2591 Location: Ipswich
 Posted: Tue Jul 18, 2017 5:23 pm |
Bye a new timing belt whilst you are at it.
Bye.
_________________ 31zook wrote: Makes me want something similar
cairns27
 Posted: Wed Jul 19, 2017 5:36 pm |
Thanks for the link, I'll get one. Does it really need a new timing belt, it's done between 10 & 20,00 Ks in five years. Putting the belt on was a bit hard, it didn't just slip on, I had to punch it on, even with all the adjustment let off on the thingy. At the moment I'm only driving 30K's on sealed, and 20 of dirt, and only use low range for a couple of K's.
Thanks again.
bye
greenzook89
 Posted: Thu Jul 20, 2017 8:09 pm |
cairns27 wrote: Does it really need a new timing belt, bye Personally I would whilst I had everything apart, but if you know when it was last changed just use your best judgement. Bye.
cairns27
 Posted: Tue Jul 25, 2017 5:10 am |
I've got one coming tomorrow from Bluesuzy's link, not putting a new belt on, motors passed it's useby date. I will probably wait for the old one to start leaking, I could do it in the bush now.
bye
