It is currently Sun Sep 20, 2026 11:22 pm
Vehicle: Sierra 1988 SJ51 LWB
Post Posted: Mon Sep 18, 2017 7:30 pm
Hey guys, was just wondering about the history behind the lwb sierra with standard wide track diffs.Im in the process of buying one and I haven't been able to find much info on them
Post Posted: Mon Sep 18, 2017 9:37 pm
A small number were imported around 1989 by Ateco for the NSW market. All parts are shared with an early WT SWB other than rear driveshaft and rear bumper corners and sill covers (other than the tub and chassis, obviously)
Apparently quite a few (50+) were used for rail operations and were converted to Hirail spec with bracketry for the rail wheels.
Probably the only variants which are rarer are SWB utes and WT highroof cars.
Post Posted: Mon Sep 18, 2017 10:06 pm
Provided its not just a wt maruti
Post Posted: Tue Sep 19, 2017 4:24 am
Window frame is NT wiper spacing. WT, Drivers wiper mount is a little more to drivers side
Wide Plastic flares. Later WT are steel. NT are thinner width plastic
Diff-Drum Handbrakes like later WT. NT were drum on transfer
They are a bit of a crossover model for the Japanese Suzuki's. They also did the same with the SWB, Quirky but no real unique parts, All can be found off other 1.3 models except for the 98 Coil Swb...
My Lwb was originally an 88' WT. Hightop Softop..
Maruti(India) are a different animal but with 89' in your profile, I think its Japanese
Post Posted: Tue Sep 19, 2017 7:38 am
So specs are the same as the WT sj50
Post Posted: Tue Sep 19, 2017 9:50 pm
Should be.
87' SJ50/51 is NT
88' SJ50/51 is WT with a few NT parts
89' ?
90' ?
91' SJ70 is WT
Post Posted: Tue Sep 19, 2017 9:53 pm
I'm pretty sure by 1989 the SJ70 - 10mm flange bolts/steel flare.
I believe there are 1988 build SJ70's too, but can't confirm this.
I've always heard the WT SJ50 referred to as an 88.5 model, but that's misleading - I think it's better described as an 87.5 (early 1988 production)
Post Posted: Tue Sep 19, 2017 11:12 pm
Yes mine is early 88'(will check build/compliance)
.5 must be referring to the nt/wt parts. Ive only seen the label 88.5 on here and Outerlimits4x4
Post Posted: Thu Sep 21, 2017 11:47 pm
My 88' WT, Built Jan 88', March 88' Compliance
Post Posted: Fri Sep 22, 2017 11:23 am
My 89 Sierra is an SJ50.
Vehicle: Suzuki Jimny
Post Posted: Sat Sep 30, 2017 8:10 am
My 87 Lwb is an sj51 (4 seater)
Post Posted: Sat Sep 30, 2017 6:08 pm
Hey justinboo can you post some pics of your back seat mounts, I've bought two, and neither of them fit. Are they mounted on some sort of slide ?. The back of mine are not held down, The bracket is too far back.
tar
bye
Post Posted: Tue Oct 03, 2017 4:36 am
Seats aren’t in atm rebuilding
Are u wanting the seats ? Or just the latch/ Locking mech?
I’ll take a few picks of both
They latch down or can swivel up and fold out of the way
Post Posted: Tue Oct 03, 2017 5:12 pm
The hold down thingy is too far back from the mounted seat,
bye
Post Posted: Wed Oct 04, 2017 7:52 am
It bolts down via the two hinge brackets: then swings down and locks in at the rear via lets call it a buckle, into the latch that’s bolted half way up the rear tray.
Post Posted: Thu Oct 05, 2017 7:36 am
My hold down bracket is 900mm back from the footwell, the seats just don't reach ????????.
tar
bye
Post Posted: Tue Nov 19, 2019 7:18 pm
So I forgot about this post. I ended up getting that zook. An it turned out to be a WT LWB Sierra SJ51 built January 1988. Can’t wait to get it on the road
Post Posted: Tue Nov 19, 2019 7:22 pm
Score!!!!! Post pics!!!
Post Posted: Wed Nov 20, 2019 6:25 am
So most of the body is good except for the rear tubs, foot wells and under the seats which I’m in the process of repairing. The motor was a goer but I have lost spark...? Going to replace all bushes, seals an bearings in the near future whilst replacing a broken front axil
Users browsing this forum: No registered users and 61 guests
