It is currently Sun Aug 02, 2026 7:27 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Vehicle: 2012 Jimny
Post Posted: Fri Aug 16, 2013 9:02 pm
damn I just ordered some of them hi clones! maybe i will cancel that order and get some of those magnet things for my fuel lines instead!
Vehicle: sj51
Post Posted: Fri Aug 16, 2013 9:30 pm
run both... and get some snake oil too... its slippery stuff ;)
Vehicle: 2012 Jimny
Post Posted: Fri Aug 16, 2013 9:36 pm
fuck that snake oil thats shit get some of those moth balls for in the fuel tank much better
Post Posted: Fri Aug 16, 2013 9:37 pm
N00b Talk
Flame proof zone, for recurring and newbie questions, only helpful replies in here or bans all round
:wink:
Vehicle: sj51
Post Posted: Fri Aug 16, 2013 9:43 pm
when the o.p. gets in on the action surely everyone realizes its just a bit of fun,
on a side note,
i truly believe that snake oil, hi clones and fuel line magnets all do their job perfectly......
if their job is to assist sly fookers in legally stealing cash from stupid people
my bad
Vehicle: 89 Holden drover high top 1.3
Post Posted: Sat Aug 17, 2013 7:01 pm
I have a Subaru one fitted which has a shroud build in fits perfectly just to make up brackets to bolt it up.
Then I have ordered a temp cut in switch off eBay which cuts in and stays on as long as the coolant temp is a above 80 degrease, it's generic but screws straight into the manifold This triggers a relay.
And if you buy a quality relay and waterproof holder and wire it with heat shrink and condute it will be reliable
And I will prob put in a switch and diode that will slow me to trigger it from inside if I want to also
Vehicle: 2012 Jimny
Post Posted: Sun Aug 18, 2013 10:18 pm
Thanks Red89 and Sleepdawgy for the good info very helpful :peaceout:
I've got that SPAL fan on its way its only 2inch profile so will have good clearance from the front of the motor, hopefully its going to fit diameter wise should, going by my measurements but some times its hard to know until your putting it together.
Vehicle: 2003 Suziki Jimny
Post Posted: Mon Aug 19, 2013 2:00 pm
If you want the most effective fan ever, put some TEK screws through the clutch :lol:
I've had to do that on a holden rodeo I used to drive for work - the "incredibly simple and reliable" viscous clutch fan wouldn't kick in to stop it from overheating until it almost cooked the motor, then it cooled down to below normal operating temp when it finally did kick in - hence the tek screw was installed to get us home. granted it had a bad head gasket, but still it shook my faith in the mechanical fans.
Can't wait to see the install pics, i'm keen to do this to my jim eventually.
Users browsing this forum: Google [Bot] and 97 guests
