It is currently Sat Aug 01, 2026 12:08 pm
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Vehicle: Toyota Hilux
Post Posted: Thu Feb 27, 2014 5:38 pm
jimny_timmy wrote:
The little OL sticker is opposite lock... Not sure they make bars though???
Pretty sure they chuck that on everything they sell haha regardless or brand.
Hmm doubt it but was wondering if it has a winch mount.
Can't check because I havnt got the car yet
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Feb 27, 2014 6:42 pm
Yeah that's what I reckon too lol
Vehicle: WT sierra, GU CRD
Post Posted: Thu Feb 27, 2014 8:07 pm
They don't AFAIK. They contract people to build them or import them after some reading on this subject.
I love ZD30. :)
Post Posted: Fri Mar 14, 2014 10:07 pm
Everything out, tub liner paint down!
Post Posted: Mon Mar 17, 2014 9:07 am
Good work stef, whats next?
I love ZD30. :)
Post Posted: Mon Mar 17, 2014 12:23 pm
I've just finished speakers and head unit, couldn't deal witjout having some ok sound.
Was nearly going to put a boat sound system in to keep it waterproof but this will be a budget build, so decided against.
Next will be around a 3" lift, and then I'll decide on a tire size. Really would like to keep stock sizing because like I said it's a budget build unlike my hilux an I don't want to destroy economy. Maybe go up an inch or two though...
Post Posted: Tue Mar 18, 2014 6:38 am
Just say no to a 3" lift. It won't make the car better in any way. More lift = less flex and harsher ride.
Vehicle: sj51
Post Posted: Tue Mar 18, 2014 2:56 pm
If you want stock size tyres, keep it at stock ride hieght... makes sense yeh?
Post Posted: Tue Mar 18, 2014 10:01 pm
Want it look a bit cooler, as I've said I have a pretty serious hilux for off road driving.
Post Posted: Wed Mar 19, 2014 12:02 am
This the look you're going for?
I love ZD30. :)
Post Posted: Wed Mar 19, 2014 4:59 am
Classic forum! [THUMBS UP SIGN]
Post Posted: Wed Mar 19, 2014 6:06 am
Well a 3" lift and stock sizes tyres will certainly make it look and work more like a hilux, if thats what you're going for.
Post Posted: Wed Mar 19, 2014 6:19 am
Thanks Steve
Post Posted: Wed Mar 19, 2014 10:52 am
Hehe thought i'd get a bite there- disappointed troll is disappointed. :D I am being kind of serious though-
You'd be far happier with less lift and larger tyres, both on and off road. Sierras can run very soft springs because they are spring under and you really want to limit the height as much as possible to improve stability.
Post Posted: Wed Mar 19, 2014 11:55 am
Couldn't agree more mate, I even went as far as cutting the wheel arches 6" open to avoid body lifting and to get 35s on.
This won't be an extreme car so just going to have fun with it. They look grouse with a bit of lift.
I'll just body lift, vitara gears and 31s for now
Post Posted: Wed Mar 19, 2014 11:59 am
A 2" BL is all you need to clear 31's. No other /more lift is required or desirable.
I'm not a fan of vitara diff gears to offset 31's- it's twice the reduction you need to offset the tyres on road but less than half of what you need offroad, but if you get them cheap and can properly set them up cheaply then they *might* be cheaper than transfer gears.
Post Posted: Wed Mar 19, 2014 12:29 pm
What else would you suggest?
Can't imagine it would move to well without a regear so I better sort it before fitting the tires
Vehicle: 92 wt soft top sierra
Post Posted: Wed Mar 19, 2014 12:31 pm
Put a leafy transfer case in with reduction gears from low range offroad
Steve will be able to go into detail on that one
Post Posted: Wed Mar 19, 2014 12:46 pm
Oh just twigged you have a coiler. Sorry, vitara diff gears do not fit the front of a coiler. There are no alternative diff ratios for a coiler at all.
You need a 1.0 litre 4wd switch equipped transfer case, or ideally a 1.3 sierra transfer case with reduction gears fitted in order to correct the gearing for 31" tyres.
Post Posted: Wed Mar 19, 2014 1:04 pm
viewtopic.php?t=45467
Youve probably seen this thread already but this is a good thing to see why gears are the go
Post Posted: Wed Mar 19, 2014 1:48 pm
Yea dam didn't realize that I couldn't change diff ratios in a coily! Shit!
What my looking at to have my transfer case re-geared?
Can I just ask the stupid question.. Does transfer case get effected by diff gears anyway? Just wondering because you said diff gears from the vitara is over kill but under kill off road.
As in if let's say I double my
Post Posted: Wed Mar 19, 2014 1:56 pm
The transfer case in a coily won't accept transfer gears from LROR and thats why you need a transfer case out of sj70 widetrack leafy or a switched 1l case but personally go the leafy sj70
Transfer case gears do a small reduction in high range and a large reduction in lowrange which is what you want because sierra lowrange isnt low enough
Post Posted: Wed Mar 19, 2014 2:03 pm
That makes sense! So will a stock sj70 case bolt right up? And will I be able to use a stock one or need to change gearing in it?
Post Posted: Wed Mar 19, 2014 2:04 pm
If there's a shop in Melbourne, I'd almost rather just let them do it and wear the bill. So long as it will be spot on
Its about 800 to build a geared transfer.
Forget the vit diff gears, but what steve means is they reduce your gearing more than you need to correct for 31's.
My maths is dodgy but it says 5.12s (is what the vit gears are I think) are 76 % lower than 3.9's (which is coily ratio right?)
Your tires are 20% bigger at most.
This reduction could work offroad but wont be as much as a set of 6.5:1 transfer gears (20% reduction in high range, something huge like 167% in low), on road or off.
Stock SJ70 case will not do, it will need reduction gears.
I love ZD30. :)
Post Posted: Wed Mar 19, 2014 2:12 pm
Awesome bit of info mate! Cheers! So I'll keep my eyes pealed for an sj70 transfer case with reduction gears.
Can I just confirm, would that bolt right in?
Post Posted: Wed Mar 19, 2014 3:01 pm
With the jack shaft and front driveshaft from a sj70, yes.
Post Posted: Wed Mar 19, 2014 3:02 pm
I'm actually spewing I can't get reduction gears got my case. Would prefer that
Post Posted: Wed Mar 19, 2014 4:11 pm
You'll get used to that feeling with a coiler :D
Post Posted: Wed Mar 19, 2014 5:18 pm
Hahaha yep I sure will. Not that easy to find a transfer case either
Users browsing this forum: No registered users and 76 guests
