| Author |
Message |
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Sat Dec 19, 2015 12:15 pm |
35's on a GV is baaaaaaad mojo. There are (early) plans afoot for a new-ish build. So far it's just a set of tyres, a chassis, two diff housings, a cab and a heap of tube, and some axles on order from tanshi. Once it's actually rolling (and fully in my possession) I'll kick off some sort of a build thread. For now, I'll just leave this here as a teaser: NT spaced vit-based housing with sierra ends set up for disc brake rear and full float with chromo axles to drop in to suit.
pete_79
Vehicle: 91 Tin Top
 Posted: Sat Dec 19, 2015 1:55 pm |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Sun Dec 20, 2015 6:17 am |
From what I've seen, yes, maxxis bias tyres need very very low pressure to work due to the stiffness of the sidewall.
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sun Dec 20, 2015 11:36 am |
My 33" Centepedes I use to run at 2-3psi off road and the same for my 38" Creepies above that they struggle to grip a little too much. I have never really 'needed' beadlocks the Pedes would just get gravel in the bead every now and then that was easy enough to clean out but I have only ever rolled the bad once in 6 or so years even doing the higher speed stuff I do these days.
TEKNO
Joined: Wed Jan 21, 2015 6:28 am Posts: 155 Location: Southern Adelaide
Vehicle: 2012 SUZUKI JIMNY M18A AUTO
 Posted: Mon Dec 21, 2015 8:11 pm |
Sorry for the hijack and forgive my ignorance but I'm still running HT Bridgestone duellers from factory now I know on the last rotation he put in and told me to run 42psi.....should I also be running around 20 psi on my 2012 jimny? Tanku
1DYX
Joined: Mon Jan 14, 2013 2:48 pm Posts: 435 Location: Eastern Suburbs WA
Vehicle: 1997 Sierra SJ80
 Posted: Mon Dec 21, 2015 8:14 pm |
yes!. Although I see you are in SA. I seem to remember somewheres, that tyre pressures had to be higher in Adelaide, due to the Barrossa Valley being there... Could be wrong, though.
TEKNO
 Posted: Tue Dec 22, 2015 12:42 pm |
Ok so I checked my placard this morning and it read 23 front and 26 rear so I dropped them back to 24psi each corner,it sure rides better now. They were all on 39psi,I will always check in future.
Qthefun
Joined: Wed Nov 25, 2015 8:07 pm Posts: 332 Location: Brizzy
Vehicle: Suzuki Jimny Sierra 2015
 Posted: Tue Dec 22, 2015 10:39 pm |
Got mine out of the show room with 42 psi in them... felt like slapping someone... who in there right mind puts people in danger (people who don't know any better).
In saying that I have them at 32 (is what feels comfy) for road but might drop them down a bit after reading this!
