It is currently Sat Aug 01, 2026 12:09 pm
Post new topic Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Vehicle: WT sierra, GU CRD
Post Posted: Wed Mar 19, 2014 5:39 pm
Something WILL eventually come up on here on Auszookers, if you're willing to wait.
Luckily your in Melbourne so you won't get reamed on freight.
You might get lucky and get a case with gears already in it from here. People sell for good prices too.
I love ZD30. :)
Vehicle: Drover pickup turk
Post Posted: Wed Mar 19, 2014 5:52 pm
There is one on eBay in Geelong.
http://www.ebay.com.au/itm/Suzuki-Sierr ... 2a39933617
I like the tuna here
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Mar 19, 2014 6:11 pm
I have a case here if you can find some gears for it. It's sitting in a project that I have and it's getting replaced. You'd have to find the shafts from somewhere though
Vehicle: 92 wt soft top sierra
Post Posted: Wed Mar 19, 2014 6:15 pm
Ive got a jackshaft out of a sj70 but im in qld
Vehicle: Toyota Hilux
Post Posted: Wed Mar 19, 2014 6:55 pm
To be honest I'm thinking about a stock 1l transfer at this stage. Ill do a lot more reading before deciding fellas! Thank you all very much
Post Posted: Thu Mar 20, 2014 4:12 pm
What's this white pipe do. Can I ditch it to fit my snorkel on better?
Post Posted: Thu Mar 20, 2014 5:39 pm
Essentially its the warm air intake. I cant remember the correct name for it.
It is a system where the intake air temp is controlled when its cold outside.
It helps a lot!
If you remove it, it may run horrible when its cold (cool and humid), and/or will eventually stall due to the carby icing up.
I removed mine and put it in the bin when I put my snorkel on, thinking it wouldnt really matter.
After a couple of winters, i rigged up a manual setup because the carby icing up drove me nuts.
It all depends on the conditions and weather you drive, but it does make a difference.
Having to pull over and stop for a few mins every 5-10 mins of driving sucks butthole.
It doesnt need to be freezing to ice the carby up.
The venturi effect in the carby and the heat the fuel absorbs when it evaporates can be enough to freeze the water in the air.
Ive found its usually when wide open throttle, and sub 10 degrees and raining/foggy/misty etc
Sometimes driving into the mountains etc will do it too.
Consider a manual setup to help the snorkel seal to the airbox.
You can do that when you prepare for offroading at the meetup point whilst airing down etc.
But id keep this piece activate for onroad use.
Post Posted: Thu Mar 20, 2014 8:54 pm
You know way to much haha! Awesome!!
May just run a flexi pipe type instead of my alloy one I bought, will just be easier I think.
If anyone's after an alloy snorkel shoot me a message
Post Posted: Mon Mar 24, 2014 11:47 am
Is the following absurd price at 1000?
Dear steve_right,
Sj70 xfer case with brand new set of gears in it with hand brake fitted to transfer case Trail tough gears 20% lower in High range and 187% lower in low range...
Post Posted: Mon Mar 24, 2014 11:52 am
The gears can cost any where inbetween US$600-$750 without postage and what you have is with t case and fitted I dont think its too bad but have you asked if that the best they can do
Post Posted: Mon Mar 24, 2014 12:00 pm
For a new set of 6.5 gears (that ratio is not trail tough AFAIK), but the price seems about right.
http://www.lowrangeoffroad.com/index.ph ... cases.html
Is that including the core charge?
You may (most likely) still need flanges, and case mounts etc too
The high range will be lower than what you are looking for.
Post Posted: Mon Mar 24, 2014 12:12 pm
Dear steve_right,
Where from?
6.5s from LROR are currently $599 + Gear Install Supplement Kit $115 + postage ~$60. Thats ~$853 with current exchange rate.
You still have to factor in price for a 1.3 TCase and getting it rebuilt.
IMO that price isn't too bad.
Post Posted: Mon Mar 24, 2014 12:35 pm
Hmm yea it's been fully rebuilt, so actually having a think about it. His also happy to install for 200 and include anything needed. Ill bargain with him but needed to see it was some where in the ball park.
It seems this type of set up would be ideal for about a 32" tire which is no issue for me
Post Posted: Mon Mar 24, 2014 12:43 pm
Probably need a body lift or do some cutting to fit a 32.
You'll likely start breaking stuff too.
I love ZD30. :)
Post Posted: Mon Mar 24, 2014 12:46 pm
Yep there will be 2" body lift and plenty of cutting. Will ride on 31s and see if I can get away with it.
Post Posted: Mon Mar 24, 2014 2:23 pm
Most important factor with the 6.5s
Are the gears new or someones second hand case?
Will you get the warranty (and I mean get the warranty, not just their word) on the 6.5 gears? or will you get ass ripped paying new prices on second hand gears and no warranty?
Also good luck with not breaking things :)
Post Posted: Mon Mar 24, 2014 2:58 pm
Are 31s really that extreme on a sierra it will break?
Post Posted: Mon Mar 24, 2014 3:04 pm
You got a coily, so yes. Thats why we asked you why you got one.
It'll definitely go places and be very capable on 31s that by most accounts will wheel with trolls and cruisers and stuff on 35's. 33's + on a sierra gets to be a pretty serious fourby.
If you gear it and run a rear locker on 31's, you will be very pleasantly surprised with where it gets you.
I love ZD30. :)
Post Posted: Mon Mar 24, 2014 3:43 pm
In terms of breakages, what's should I be concerned about?
Post Posted: Mon Mar 24, 2014 4:12 pm
I'm not a coily guy, but in leaf versions its mainly CVs and twisting / breaking axles. With low gearing in the transfer case you can damage the transfer case mounting arms if they're not braced / replaced with better items.
31s on stock axles etc shouldn't give any trouble if you drive sensibly.
As you go over 31s (some people on 31's as well) you get closer to these things limit.
I love ZD30. :)
Post Posted: Mon Mar 24, 2014 4:22 pm
Yep great points! Coming from a hilux on 35s I've had to adjust my off road driving to a very smooth and sensible style haha!
Good thing is you're not up for 5 grand every time you break something on a sierra!
Thank being said, I will be upgrading as I go.
You guys have been awesome help! Appreciate everyone's input
Post Posted: Mon Mar 24, 2014 4:31 pm
Honestly an IFS Hilux on 35s is probably more likely to break.
My mates broke heaps on 31s, my other mates IFS rigs are similar (Triton etc.) .
Edit: Sorry if I'm coming off as rude, I'm not trying to be.
I love ZD30. :)
Post Posted: Mon Mar 24, 2014 5:06 pm
Not rude at all!! That's reality!!
Breaking parts is part of the sport. I understand everyone says you can drive to or set up to prevent, but let's face it, it happens!
Post Posted: Tue Mar 25, 2014 5:49 pm
Best mod so far haha! Somewhere to put the coffee!!
Post Posted: Tue Mar 25, 2014 6:50 pm
Don't forget coil sierras have weaker cv's than leaf cars and there is no bolt in fix like a WT car. 31's are ok on stock cv's in Victoria, but if you are abusive or weld (or work out how to otherwise lock) the front end the front cv's will become an issue.
Post Posted: Tue Mar 25, 2014 6:53 pm
The way I drive this car I can't see it being an issue but I'll keep it in mind! Thanks mate
Started the snorkel install and the bloody hole saw shit itself so frustrating!
So threw new flaps on for a bit of fun
Post Posted: Thu Mar 27, 2014 2:57 pm
Post Posted: Thu Mar 27, 2014 4:52 pm
Ahh so the snorkel is finished?
Looks good
Post Posted: Thu Mar 27, 2014 8:44 pm
Haha will post a pic of the finished product. Looks a bit dodgy but for a budget set up it does the job.
Not sure it will actually function with the hot air intake still installed
Post Posted: Fri Mar 28, 2014 6:27 am
Interested to see how my economy is effected
Users browsing this forum: No registered users and 71 guests
