It is currently Sat Nov 14, 2026 3:05 pm
Post Posted: Fri Mar 16, 2012 5:24 am
Hi there.
I just got some wheel cylinder for the back of my 1.3 84 model sierra and they are differant part numberes left and right.
They look the same and I thought they were. I even pulled them apart cause I was certain that they were the same.
My question is: are they the same left and right? I'm sure it's an easy question for the omnipotent ones out there. LOL.
Vehicle: chick magnet coily
Post Posted: Fri Mar 16, 2012 6:01 am
what do you mean by ''wheel cylinders"
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Fri Mar 16, 2012 6:58 am
one is left and one is right because the brake line comes into your drivers side then goes across from that to the other one. so only the passenger side has a bleed nipple on it. if you look at them you should have one with a bleed nipple and one with out.
a wheel cylinder is much like a caliper but for pushing the brake shoes in drums apart instead of pushing brake pads together
I love lamp
Post Posted: Fri Mar 16, 2012 7:11 am
^^^^^^ What this bloke said
Post Posted: Fri Mar 16, 2012 5:56 pm
On the late models I think the brake line goes from one side to the other, horizontal split system. But this has individual lines.
Post Posted: Sat Mar 17, 2012 6:56 am
Maybe someone before you has changed it? I dunno then maybe someone else a bit more knowledgeable will pipe up haha.
I love lamp
Post Posted: Sat Mar 17, 2012 8:44 am
Take them back then. I think the earlier Sierras did have individual lines
Vehicle: 75 Cruiser
Post Posted: Mon Mar 19, 2012 8:22 am
I think they're the same left and right
you just put the bleed valve in one side instead of the brake line for the later model ones, and just put a bleed valve in each side for the early model ones?
Post Posted: Mon Mar 19, 2012 8:26 am
Na, the line and nipple seats are different
Vehicle: 75 Cruiser
Post Posted: Mon Mar 19, 2012 8:30 am
ahh ok, i think it still works though ? I've probably used the wrong ones on the wrong sides at various times.
Post Posted: Tue Mar 20, 2012 9:28 pm
Thank you. That was what i was thinkin. I'll have to look closer. Just whacked em on the shelf till I get my diff back. I dont mind checkin the brake fluid before I head to work. Pretty lazy like that!
Users browsing this forum: No registered users and 13 guests
