It is currently Tue Nov 03, 2026 7:32 pm
Post Posted: Sat Mar 24, 2012 7:23 pm
Alrighty started looking at suspension for the short one (03 SQ420) :D
Going to go with Dobinson 35mm springs and struts with 30mm spacers in the rear
Now i want to run 30mm spacers on the front aswell but i'm not sure if the dobinson struts will be ok with this or will i need a strut spacer aswell?
I'm going to run diff drop brackets too
Cheers, Joe
Post Posted: Sat Mar 24, 2012 7:32 pm
front's only need a 1/2 sized spacer to the rear due to the position of the spring in relation to where the wheel it.
eg, 15mm front & 30mm rear
have a suss of chop's build, he's running spacers. not sure what size & if he's got diff drop brackets.
Vehicle: 02 GV
Post Posted: Sat Mar 24, 2012 7:35 pm
I have 17mm (equal to 34mm) spacers with 40mm springs and Ironman struts which are 40mm longer. I don't seem to have a problem and no top out. no diff drop brackets.
Post Posted: Sat Mar 24, 2012 8:02 pm
Kate's GV has the same set up as Chops (15mm front & 30mm rear) :wink:
The front end on Kate's sits abit lower then the rear when unloaded
I like how this one sits even front & rear (this has 30mm coil spacer up front)
Also id like to run with a front bar and winch one day
