| GV suspension question http://auszookers.com/forum/viewtopic.php?f=37&t=31416 |
| Author: | Joe [ Sat Mar 24, 2012 7:23 pm ] |
| Post subject: | GV suspension question |
Alrighty started looking at suspension for the short one (03 SQ420) Going to go with Dobinson 35mm springs and struts with 30mm spacers in the rear Now i want to run 30mm spacers on the front aswell but i'm not sure if the dobinson struts will be ok with this or will i need a strut spacer aswell? I'm going to run diff drop brackets too Cheers, Joe |
| Author: | atari4x4 [ Sat Mar 24, 2012 7:32 pm ] |
| Post subject: | Re: GV suspension question |
front's only need a 1/2 sized spacer to the rear due to the position of the spring in relation to where the wheel it. eg, 15mm front & 30mm rear have a suss of chop's build, he's running spacers. not sure what size & if he's got diff drop brackets. |
| Author: | bailey08 [ Sat Mar 24, 2012 7:35 pm ] |
I have 17mm (equal to 34mm) spacers with 40mm springs and Ironman struts which are 40mm longer. I don't seem to have a problem and no top out. no diff drop brackets. |
| Author: | Joe [ Sat Mar 24, 2012 8:02 pm ] |
atari4x4 wrote: front's only need a 1/2 sized spacer to the rear due to the position of the spring in relation to where the wheel it. eg, 15mm front & 30mm rear have a suss of chop's build, he's running spacers. not sure what size & if he's got diff drop brackets. Kate's GV has the same set up as Chops (15mm front & 30mm rear) The front end on Kate's sits abit lower then the rear when unloaded ![]() I like how this one sits even front & rear (this has 30mm coil spacer up front) ![]() Also id like to run with a front bar and winch one day |
