It is currently Mon Nov 02, 2026 11:06 pm
Vehicle: 1995 suzuki sierra hardtop
Post Posted: Tue Apr 03, 2012 9:30 pm
Hey guys as mentioned above, Id like to know how to change the gearbox oil. Whats the best way to get to the filler in a 95 suzuki sierra and how much and what type do I put in. Thanks
Vehicle: Clown Car..
Post Posted: Tue Apr 03, 2012 9:57 pm
pretty sure its been explained previously, but in short... bottom of gearbox, undo sump, allow oil to drain, take note of colour and quantity. Check FSM for recommended amount, remove 4 10mm bolts around gear lever, remove gearstick, fill with required amount of oil, replace removed parts. there is also a fill point on the side of the gearbox, if you undo that and fill the box till it drains from there, its a good indication the level is correct.
check the FSM for the recommended oil. Off memory I think im running VMX80.
FSM is factory service manual, its available for download.. (will have to search, dont know the link off top of my head)
But thats basically it..
isnt a hard task to do, worth checking the shift bolt is still in one piece while you are in there with the shifter removed..
Post Posted: Tue Apr 03, 2012 10:15 pm
Thanks mate muchly appreciated
Post Posted: Tue Apr 03, 2012 10:18 pm
all in an evenings work. If you get stuck... yell out, am sure there are members from wherever in Vic you are from.. or at least somewhat close by willing to lend a helping hand.. if not, PM me and will help out how ever I can..
Post Posted: Wed Apr 04, 2012 4:52 am
If ya doing it on your own without the correct square drive (10mm), take the filler bung on the side of the gear box out first.
Then drain ,Use a squeeze bottle and fill to overflow.
bye
Post Posted: Wed Apr 04, 2012 5:03 am
:peaceout: :peaceout: Absolutely
Post Posted: Wed Apr 04, 2012 9:44 am
Just did mine last night along with the gearbox and diffs
Got Castrol VMX-80 (or VMX-M) and change your transfer oil also while you're at it
Could pay to get one of these from AutoOne (think it was $30) and that way you save yourself undoing the top bolts etc
http://www.lubemate.net.au/auto/thumbna ... yle=padded
Also, just for future reference, there is no need to buy the "special 10mm square" socket....just use the normal 3/8" drive with extension...it fits perfectly ;)
