It is currently Thu Nov 05, 2026 5:05 am
Post Posted: Wed Apr 18, 2012 7:43 pm
When tapping a thread is it necessary to use some form of lube ? I have been using a dry lube stick, what sort is recommended ? I am needing to do a heap of M6 threads, but after drilling a 5mm hole I seem to be chewing out the thread on the tap and it certainly doesnt want to start easily. It does eventually bite and cuts fine once it gets going but it seems to take forever to get started :x
Made in JP. Built in WA.
Post Posted: Wed Apr 18, 2012 8:03 pm
What are you tapping in to? I use cutting lube and often tap with a cordless drill at that size.
Correct drill size is 4.8mm, are you using a taper or inter tap, or a bottoming tap? Bottoming taps can be very hard to start.
Post Posted: Wed Apr 18, 2012 8:17 pm
you can get taps in 3 types, taper, intermediate and bottoming. a taper tap is needed to cut a new thread, intermediate is good for cleaning our a previously cut thread, and a plug tap is used for tapping into a blind hole (after starting the thread with a taper tap)
Get some rocol rtd or trefolex, they are proper cutting compounds and will make a massive difference to the ease of tapping and life of the tap.
Steve the correct drill size for a 6mm tap with 1.0mm pitch is 5mm. Where do you get 4.8 from?
Post Posted: Wed Apr 18, 2012 8:20 pm
i use trefolex alot, make sure you get the right one, there high speed trefolex and cutting compound trefolex.
Vehicle: 1985 Holden Drover
Post Posted: Wed Apr 18, 2012 8:26 pm
zooky08 wrote:
i use trefolex alot, make sure you get the right one, there high speed trefolexmand cutting compound trefolex.
x2. Only stuff we ever use at work.
1989 WT Sierra.
Post Posted: Wed Apr 18, 2012 8:32 pm
Oops- pwned- I was thinking 8mm with a 1.25 thread - 6.8mm
Steve
Post Posted: Wed Apr 18, 2012 9:00 pm
The cheapo tap set Ive got only has intermediate and bottoming taps, I have been tapping into 2.5mm pipe and flat bar. Looks like I'm off to the toolshop, cheers guys.
Post Posted: Fri Apr 20, 2012 1:18 pm
Yep cheapo taps are exactly that.
Get sutton or similar from a proper toolshop
Post Posted: Fri Apr 20, 2012 3:35 pm
X2. And if you are tapping by hand, drive the tap in one full turn, then back half a turn. This will clear the swarf from the tap and help prevent the new thread from being burred.
Post Posted: Fri Apr 20, 2012 6:24 pm
Life is sooo much easier when you have the right tools :roll: Bought a taper tap and some Rocol ( they had run out of Trefolex ) the other day and ran off 12 threads this arvo in the same time it would have taken me to do 2 before, cheers all Armsup
Yer it appears most are simply thread repair kits not tap and die sets.
I do remember that much from highschool metal work :wink:
Post Posted: Sun Apr 22, 2012 5:13 pm
I once had to tap a new thread into an old holden diff housing. I could not get a good start because I was working on my back, and just could not keep it straight and keep the pressure on it whilst turning the handle. My solution was to put the tap into small battery drill where I could concentrate on keeping it straight and enough pressure. Drove it slowly. Worked a charm.
Post Posted: Tue Apr 24, 2012 10:52 am
I dislike tapping with a drill, because if you smash the tap, it can be hard to remove in the job. Of course with a battery drill you can use the torque control, but can still be risky
I'd rather it by feel. Even if it is alot of holes
Vehicle: Daisy
Post Posted: Thu Apr 26, 2012 6:35 pm
I've tapped thousands of holes with a battery drill, we were doing 5mm tapped holes into C channel up the side of conveyors, we made it fun by having races with each other, I definitely wasn't going to be doing those by hand...
Also, if you manage to smash the tap in the hole, if there's enough sticking out you can usually grab on with the battery drill or pliers and wind it back out!
Post Posted: Fri Apr 27, 2012 9:31 am
Of course a conveyor is a different story.
Used to do massive rivets in a train conveyor, Weren't doing them by hand :lol: 10rivets in a line, 100mm apart, The next line was maybe 200mm away, at least 22M long belt, Including drilling..What fun..
Users browsing this forum: No registered users and 36 guests
