| Shock bushes...poly or rubber ? http://auszookers.com/forum/viewtopic.php?f=37&t=32171 |
| Author: | fully sick coily [ Sat Apr 28, 2012 2:16 pm ] |
| Post subject: | Shock bushes...poly or rubber ? |
ok so im up for some shock bushes and was wondering: what the pros cons are? whats the price range? where do i get them? any help would be great thanks max |
| Author: | matty_wall [ Sat Apr 28, 2012 2:26 pm ] |
| Post subject: | Re: poly or rubber bushes |
viewtopic.php?f=5&t=31866&hilit=sierra+bushes |
| Author: | BlueSuzy [ Sat Apr 28, 2012 2:28 pm ] |
Shock bushes? Rubber. They rarely wear out. |
| Author: | Scrawny [ Sat Apr 28, 2012 2:47 pm ] |
We're having a poll about shock bushes? |
| Author: | fully sick coily [ Sat Apr 28, 2012 5:24 pm ] |
YES!!! |
| Author: | Fatzook [ Sat Apr 28, 2012 10:36 pm ] |
Scrawn wrote: We're having a poll about shock bushes? Someone found the 'poll' option on the new post page, and had to figure out a useless topic to poll. |
| Author: | fully sick coily [ Sun Apr 29, 2012 6:48 am ] |
yes! i was wondering how it worked but i dont no what bushes to buy |
| Author: | Gwagensteve [ Mon Apr 30, 2012 11:45 am ] |
BlueSuzy wrote: Shock bushes? Rubber. They rarely wear out. And there's your answer. Steve. |
| Author: | Bruce [ Mon Apr 30, 2012 12:31 pm ] |
Gwagensteve wrote: BlueSuzy wrote: Shock bushes? Rubber. They rarely wear out. And there's your answer. Steve. Have had poly in one of my cars for over 10 years and still fine. So rubber must be the only way to go
| Author: | fully sick coily [ Mon Apr 30, 2012 12:59 pm ] |
how much would you charge for a full set of poly bushes for a 1997 coily? |
| Author: | Gwagensteve [ Mon Apr 30, 2012 1:18 pm ] |
Bruce wrote: Have had poly in one of my cars for over 10 years and still fine. So rubber must be the only way to go ![]() So what are the advantages of poly for a shock bush then Bruce? I am a big fan of your soft poly spring bushes, it's just that I don't think it really matters for a shock bush. Steve. |
| Author: | zooky08 [ Mon Apr 30, 2012 2:27 pm ] |
My rubber shock bushes disnt even last 2 months? Shit quality? |
| Author: | Gwagensteve [ Mon Apr 30, 2012 3:16 pm ] |
| Post subject: | Re: Shock bushes...poly or rubber ? |
Topping or bottoming the shocks out will split any bush - could be an issue? Steve. |
| Author: | Shansh [ Mon Apr 30, 2012 3:56 pm ] |
Gwagensteve wrote: Bruce wrote: Have had poly in one of my cars for over 10 years and still fine. So rubber must be the only way to go ![]() So what are the advantages of poly for a shock bush then Bruce? I am a big fan of your soft poly spring bushes, it's just that I don't think it really matters for a shock bush. Steve. bite bite |
| Author: | Bruce [ Mon Apr 30, 2012 5:26 pm ] |
Gwagensteve wrote: Bruce wrote: Have had poly in one of my cars for over 10 years and still fine. So rubber must be the only way to go ![]() So what are the advantages of poly for a shock bush then Bruce? I am a big fan of your soft poly spring bushes, it's just that I don't think it really matters for a shock bush. Steve. Nothing. You just say that rubber is the end of the story. I say that I have had poly for 10+ years and they are still good. I just get so pissed off that people say rubber are better or poly is better. As stated before in another post, rubber is bloody good in some things but not everything. If poly is so good why are we not driving on poly tyres |
| Author: | Gwagensteve [ Mon Apr 30, 2012 5:43 pm ] |
Is that relevant though? You've just said there's no advantage to poly over rubber for a shock bush, so aren't you just confusing a simple question with a whole lot of baggage? I never claimed I was anti poly, I endorsed your bushes, and asked why poly would be superior for a shock bush (and apparently it's not?) I too have run poly shock bushes for years without a problem, because that's what the shocks came with. I wouldn't bother swapping from one material to the other, because, like you, I don't think, in a shock, it makes any worthwhile difference. So, in fact, my response should have been replace what was in there with what came out, because it doesn't really matter what shock bush material is used. Steve. |
| Author: | Bruce [ Mon Apr 30, 2012 5:50 pm ] |
And my responce is that you say and I quote, " And there's your answer." Unquote. So you are saying that rubber is the only answer? I agree that there is no diff in poly or rubber in a shock bush but to say "And there's your answer." to me is not right either. |
| Author: | fully sick coily [ Mon Apr 30, 2012 7:18 pm ] |
so what elss can you use poly bushes in? |
| Author: | BlueSuzy [ Tue May 01, 2012 12:34 pm ] |
Most rubber mounted bushes. |
| Author: | SierraDan [ Tue May 01, 2012 11:05 pm ] |
I carve mine out of wood. |
| Author: | BlueSuzy [ Tue May 01, 2012 11:49 pm ] |
And my mate had hose ones. Not the best for shocks. |
| Author: | SierraDan [ Wed May 02, 2012 12:13 am ] |
Why?. |
| Author: | fully sick coily [ Wed May 02, 2012 4:36 am ] |
WOOD!!!! why wood, it would splinter/crack |
| Author: | Fatzook [ Wed May 02, 2012 8:14 am ] |
fully sick coily wrote: WOOD!!!! why wood, it would splinter/crack Oh lord. |
| Author: | royce [ Wed May 02, 2012 9:31 pm ] |
poly bushes can be made stiffer so the shocks will work more making the suspension nicer Probably never going to notice the difference on a 4wd though and with Suzukis awesome shock alignment probably snap the diff in half or something |
