It is currently Fri Sep 18, 2026 8:31 pm
Post Posted: Mon May 07, 2012 12:12 pm
I've got a G13BB that's going into the Coilly, and I'm going to get it rebuilt before doing the swap.
I'd like to get everything done now while the engine is out of the vehicle, with the hope that it will give years of solid service.
I'm not looking for any performance increase, just an honest motor.
What is involved in a complete rebuild ? (What should I get quoted for ? )
Any recomendations for quality parts or kits that I can source for the shop to use ?
Cheers.
Post Posted: Mon May 07, 2012 12:30 pm
Full rebuild means..
Bore block.
New pistons and rings.
Grind crankshaft if needed.
New main bearings.
Resize rods.
New B/E bearings.
New oil pump.
New water pump.
New timing belt and tensioner.
Full head service.
ACL are good gaskets, pistons, rings and bearings.
Post Posted: Mon May 07, 2012 9:21 pm
had bottom end rebuilt machine work alone was about $700
Post Posted: Tue May 08, 2012 10:27 am
Machine work alone $700 :shocked: WTF did you get done?
Bore/hone and a crank grind shouldn't be anymore than $300 max for a tiny 4 cylinder.
Even decking the block would only add another $50 or so.
Vehicle: Ducati Monster
Post Posted: Tue May 08, 2012 10:39 am
i got the crank ground, block decked, honed & cleaned plus head skimmed & cleaned & he pressed my new pistons on my rods for me, that was $200 mates rates. i got a quote from another machine shop they wanted over $400 for just the bottom end work!!
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat May 12, 2012 8:17 am
I had a g13 a rebuilt (ba) rebuilt it cost me 1500 but mates rates if u had a g13bb rebuilt it may cost about 2500 do to the double over head cam or maybe slightly cheaper no connections,I'd nearly get a low k 1 from a jimmy for that I mean surly u could still get a nice 1 for under 800
Green? greeeen is nice !
Post Posted: Sat May 12, 2012 6:04 pm
Its not a DOHC engine!!
We are just putting back together a G16B with new head, bored, new pistons, rings, crank machined, big end bearings, main bearings and a full gasket set for ~$1800. Head was ~$500 alone to give you an idea of the costings.
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Sun May 13, 2012 9:12 am
Lol head as well
Post Posted: Sun May 13, 2012 10:42 am
Thanks all.
Users browsing this forum: No registered users and 65 guests
