It is currently Thu Nov 05, 2026 3:35 pm
Vehicle: 89 Sierra, 2in Leafs.
Post Posted: Thu May 10, 2012 10:33 am
Hi Guys, I'm new to the forum & I am after some advise. I have a 89 Sierra that I have fitted 2in EFS leafs & all new bushings with extended shackles & 30" tyres on 7" F100 rims. Since fitting the lift the car gets "deathwobbles" at 80kph. We have balanced the tyres, adjusted the steering box, removed the sway bar & fitted a Tough Dog RTC steering damper & we are still gettig the wobble. Any suggestions on how to solve this issue would be greatly appreciated.
Post Posted: Thu May 10, 2012 12:11 pm
Check the toe.
Check kingpin bearing condition and preload.
Check wheel bearings.
Go get a wheel alignment and ask for the caster figures. You may need to fit caster wedges between the diff perch and the spring.
Post Posted: Thu May 10, 2012 1:48 pm
After that, extended shackles may need to addressed.
Post Posted: Thu May 10, 2012 2:52 pm
Make sure your ubolts are all evenly tight, and tight enough
do your shackles up tighter, if it changes the wobble remove them and fit the stock ones and try that
Post Posted: Thu May 10, 2012 6:26 pm
Put the stock shackles back on - 90% it will go away. You've reduced the caster.
Post Posted: Fri May 11, 2012 9:09 am
if your getting 80km/h out of it before it starts wobbling i would check the wheel balance.
Users browsing this forum: No registered users and 50 guests
