It is currently Tue Nov 03, 2026 12:59 am
Post Posted: Wed May 16, 2012 4:34 pm
i have 30mm of 10mm winch rope.
tried to put it on and seems to long and wont wind all the way in?
how long/size are your ropes and how can i fix this
cheers
Ricky
93 sierra 2"spring2"body 31,s & 4.9s
Vehicle: 03 Jimny
Post Posted: Wed May 16, 2012 4:44 pm
what size winch? my 9000lb has 30m on it
Post Posted: Wed May 16, 2012 4:45 pm
Did you try to put in on under some type of load?
Post Posted: Wed May 16, 2012 4:49 pm
yeah i was using load but the mrs was helping me and she is somewhat special. should i drag it up a hill? that was my next plan maybe im just retarded
Post Posted: Wed May 16, 2012 4:55 pm
drag it up hill with the hand brake on a few clicks for some more resistance, it needs to be spooled on under some actual load.
Post Posted: Wed May 16, 2012 5:02 pm
i put mine in first gear low range with the hubs locked and motor off, attach the cable to something heavy and winch the car to it.
Vehicle: 03 Jimny
Post Posted: Wed May 16, 2012 5:04 pm
do you actually have to use that much load? i just wind mine on through my hands keeping a firm grip. my rope is 30m by 10mm aswell. must be some thing else wrong eaither you have a small winch, barrel is too big or not enough space between the barrel and the bars that join motor and gearbox.
Post Posted: Wed May 16, 2012 5:05 pm
No you don't have to use a hill. Put it to another car and either drag the car to you or the other way around.
Vehicle: 03 Jimny
Post Posted: Wed May 16, 2012 5:08 pm
well i dont use anything accept a firm grip with my hand.
Post Posted: Wed May 16, 2012 5:11 pm
We still talking about winch ropes? :lol:
Post Posted: Wed May 16, 2012 5:13 pm
No where near enough pressure.
Vehicle: 03 Jimny
Post Posted: Wed May 16, 2012 5:15 pm
i was waiting on that :thefinger:
Post Posted: Wed May 16, 2012 5:20 pm
didn't you have the rope pull off the drum recently? :roll:
Vehicle: 03 Jimny
Post Posted: Wed May 16, 2012 5:23 pm
yep wounded the rope into to much to often after the hook hit the fair lead and snaped the rope of the drum
Post Posted: Wed May 16, 2012 6:42 pm
Unlike the reel on a fishing rod, you may have to spool in on.It may be bunching up in one place .
Use a leather glove.
bye
Post Posted: Wed May 16, 2012 6:44 pm
why bother with a leather glove when handling synthetic winch rope... :roll:
Post Posted: Wed May 16, 2012 7:22 pm
I think he is suggesting that you wil get a tighter grip on the rope while spooling.
bye
Post Posted: Wed May 16, 2012 10:05 pm
If you don't spool on under load the rope will be loose on the drum.
When you use the winch next, you may only need to unspool 10-15 metres. Then when you winch in under load you will pinch the rope on the drum and it will be very difficult to unspool next time.
That is the only disadvantage I have found RE: Rope Vs Cable.
Users browsing this forum: No registered users and 19 guests
