It is currently Fri Nov 13, 2026 4:54 pm
Vehicle: Suzuki sierra
Post Posted: Fri May 18, 2012 10:43 am
Is it worth getting a wheel alignment in a sierra.
Post Posted: Fri May 18, 2012 10:51 am
Only adjustment is toe, so unless something is visibly bent or the car is driving funny, no.
Post Posted: Fri May 18, 2012 11:02 am
The steering wheel is off centre a bit but when driving it seems to be alright.if ya let go of the wheel it goes to the right abit.ya gotta keep moving the steering wheel a little when driving though.
Post Posted: Fri May 18, 2012 12:11 pm
Do you have a steering damper?
Post Posted: Fri May 18, 2012 12:26 pm
Yea I do
Post Posted: Fri May 18, 2012 4:36 pm
What type??
Help us help you. Comeon. We cant fix everything for you.
Vehicle: SJ80, SE416
Post Posted: Tue May 22, 2012 5:26 pm
RTC damper not set correctly, brakes stuck on on one side due to stuffed bearings or stuck slides, tyre pressures uneven, bent suspension etc...
Steering wheel off-centre is normal though as it will rotate as the suspension drops as you add weight to the front end.
Users browsing this forum: No registered users and 30 guests
