It is currently Wed Nov 04, 2026 1:57 am
Post Posted: Mon May 21, 2012 3:57 pm
I am fixing up a G16B EFI Motor that cam with no head - I have got a new head and sorted out most of the pieces but I can not find anything that will fit over this hole in the rear end of the head - I guess it went AWOL with the old head. If you can tell me what I am missing it would be of help and better still would be a picture.
This is the hole picture so to speak :wink:
If you have one of whatever it is to sell would be even better.
Post Posted: Mon May 21, 2012 3:58 pm
Water way for front wheel drive motors. It just has a blanking plate for us with rwd's
Post Posted: Mon May 21, 2012 4:05 pm
That is where the thermostat housing is located on a baleno motor ( same head ).
As Scrawn said...... blank it off.
Post Posted: Mon May 21, 2012 4:12 pm
Thanks Guys - Anyone have a plate?
Post Posted: Mon May 21, 2012 6:41 pm
My G16B has a plate with a spout for one of the heater hoses.
I think I have one here. I'll dig around on the morrow.
Post Posted: Tue May 22, 2012 6:43 am
yes a water outlet goes there for the heater in my vitara
now a vitara doesnt have a heater tap to turn the coolant flow off so I wonder if Suzuki didnt want coolant to be flowing out that end of the head all the time
Also, you cant put the head bolts in with the cam fitted, youll have to take all that off :)
Post Posted: Tue May 22, 2012 7:48 am
Want33's - Just checked and yes there is a heater hose laying there so if you have one - Pretty Please ;<}
Royce - Yes the cam is just temp - Trying to make sure I have everything - Thanks
Post Posted: Tue May 22, 2012 11:06 am
Tony here is the offender...
I tried to call you earlier to see if you need any of the other bits that bolt to the head like the little steel plates that support the top of the timing cover.
Post Posted: Tue May 22, 2012 1:06 pm
That is the little sucker I imagined - I tried to ring you back a couple of times but you must be out of range or busy with something :wink:
Yes I would like the plates to if you have them - I was going to make some but your way is easier :D
Post Posted: Tue May 22, 2012 1:09 pm
No worries I'll send them off this arvo.
Post Posted: Tue May 22, 2012 8:36 pm
Anything other little bits you need Tony let me know, I'm collecting my car and old head tomorrow.
Post Posted: Wed May 23, 2012 7:51 am
I need a good pair of front seats (1992 Vitara)
Users browsing this forum: No registered users and 36 guests
