It is currently Sat Nov 14, 2026 9:29 pm
Vehicle: Stockish
Post Posted: Tue Jun 19, 2012 6:35 pm
Alright, I have searched and failed to come up with a clear answer, I know as soon as you change the tyre size the speedo will be out, but what can I do to fix the speedo? I want to fit 215/75/15 tyres in place of the standard tyres has anyone worked around this or just dealt with the speedo being out slightly
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Jun 19, 2012 6:39 pm
What model jimny have you got? 215's on a VVT will actually put it back to normal.
Edit: jaycar also do a DIY kit to fix it too
Vehicle: Stockish
Post Posted: Tue Jun 19, 2012 8:04 pm
2008 vvt manual
Post Posted: Tue Jun 19, 2012 8:07 pm
Yep 215s will correct your speedo to pretty much perfect :)
Vehicle: Stockish
Post Posted: Tue Jun 19, 2012 8:11 pm
So my speedo is out already?
Post Posted: Tue Jun 19, 2012 8:25 pm
If you're running 205/70r15, yes.
Go for a run with a gps device and you'll see it reads approx 5km/h slower than what it says on the speedo :)
Vehicle: Stockish
Post Posted: Tue Jun 19, 2012 8:30 pm
I've actually noticed that, to come to think of it I've noticed that in all the cars I've owned
Post Posted: Wed Jun 20, 2012 9:23 am
Yep, same thing happened on my 2008 Jimny.
Vehicle: SJ80, SE416
Post Posted: Wed Jun 20, 2012 9:45 am
Virtually every new car comes out of the factory that way. 3-7% under is common.
Vehicle: chick magnet coily
Post Posted: Thu Jun 21, 2012 7:23 pm
i have 30's on my coily and it isnt out
is this normal?
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Fri Jun 22, 2012 11:29 am
is this normal?
If you have a transfer from a WT fitted which is designed to have 3.7 diff gears, then the speedo would be close enough to seem correct.
Speedo gears corresponding to a 3.7 diff with 3.9 diffs will give the speedo 5% correction already, factor in 5% error from the factory and your 30" tyres are close enough to the 10% error.
Post Posted: Fri Jun 22, 2012 9:53 pm
AFIAK in Aus, speedos have to read between between 0 and 10% lower than the actual speed.... Measured at 40 and 100km/h. (I think)
My 1l with 30s still reads 3-4km slow, well it did until the speedo cable snapped the other day. :cry:
Vehicle: Suzuki Jimny 2009
Post Posted: Fri Jun 22, 2012 10:45 pm
My 2009 is now spot on with 215/75's
Post Posted: Fri Jun 22, 2012 10:56 pm
I bought the speedo correction kit from Jaycar today... Fffffuuuuuuck it's gonna take aaaaages to just build the thing lol
Users browsing this forum: No registered users and 27 guests
