It is currently Sat Nov 14, 2026 10:44 pm
Vehicle: Suzuki Sierra SJ80
Post Posted: Sun Jun 24, 2012 7:39 pm
Hey everyone,
I have a SJ80 with a 2 inch suspension lift and want to put a body lift on it and was wondering if any other modifications need to be done with a body lift or its as simple as putting the blocks under?
Also there is no leafsprung bodylifts and coilsprung body lifts is there, its all the same?
Thanks,
Trev
Post Posted: Sun Jun 24, 2012 7:44 pm
Coil BL and Leaf BL are the same.
From memory, you might want a longer brake line for the passenger side front (?) of a coiler - the brake lines are differently routed to a leaf car IIRC, but otherwise there's no real issues you won't find on here by searching. I BL'ed a coiler in the late 90's... haven't played with one since, forgive me if I've neglected something.
Post Posted: Sun Jun 24, 2012 8:37 pm
Good stuff, thanks a lot Steve.
Post Posted: Sun Jun 24, 2012 8:46 pm
At a push you can remove the FL brake line from its clip and let it float.
Users browsing this forum: No registered users and 22 guests
