| Body lift for a coily? http://auszookers.com/forum/viewtopic.php?f=37&t=33642 |
| Author: | TrevorStaader [ Sun Jun 24, 2012 7:39 pm ] |
| Post subject: | Body lift for a coily? |
Hey everyone, I have a SJ80 with a 2 inch suspension lift and want to put a body lift on it and was wondering if any other modifications need to be done with a body lift or its as simple as putting the blocks under? Also there is no leafsprung bodylifts and coilsprung body lifts is there, its all the same? Thanks, Trev |
| Author: | Gwagensteve [ Sun Jun 24, 2012 7:44 pm ] |
| Post subject: | Re: Body lift for a coily? |
Coil BL and Leaf BL are the same. From memory, you might want a longer brake line for the passenger side front (?) of a coiler - the brake lines are differently routed to a leaf car IIRC, but otherwise there's no real issues you won't find on here by searching. I BL'ed a coiler in the late 90's... haven't played with one since, forgive me if I've neglected something. Steve. |
| Author: | TrevorStaader [ Sun Jun 24, 2012 8:37 pm ] |
Good stuff, thanks a lot Steve. |
| Author: | Rusho [ Sun Jun 24, 2012 8:46 pm ] |
At a push you can remove the FL brake line from its clip and let it float. |
