It is currently Sun Nov 15, 2026 5:30 am
Vehicle: 91 sierra swb nt
Post Posted: Wed Jun 27, 2012 8:52 pm
ok people, its stupid question time again :)
i am replacing the jets in my 1.3l sierra, standard asian carby, and i have no idea where they are or how to get to them, lol..
any info is appreciated, pics are good too :)
Post Posted: Wed Jun 27, 2012 8:59 pm
why are you replacing them, are you fitting larger ones?
Post Posted: Wed Jun 27, 2012 9:25 pm
yup :)
Post Posted: Wed Jun 27, 2012 9:33 pm
viewtopic.php?f=5&t=29725&p=540556&hilit=sierra+carby+rebuild#p540556
http://www.youtube.com/watch?feature=pl ... mJHc3YjwPQ
they're in there somewhere
Post Posted: Wed Jun 27, 2012 9:53 pm
rofl, that is my thread, lucky im getting a memory test done soon, lol...
Post Posted: Sat Jun 30, 2012 12:53 am
memory test? fail, patience test is a bigger" fail, using the search feature on this site? massive fail..
so now ive got the jets in and once warm it runs sweet and can definitely feel the difference, now its a matter of curiosity and needing to get the thing starting a bit better when cold, so obviously i need to make some adjustments, im just not sure what the 2 screws on the carby adjust and which one i should adjust for the cold start ?
Post Posted: Sat Jun 30, 2012 12:28 pm
Those two screws won't help you. The one at the base of the carby adjusts the idle mixture, the other one adjusts hot idle speed.
Post Posted: Sat Jun 30, 2012 2:28 pm
what about the one under the throttle cable?
Post Posted: Sat Jun 30, 2012 2:42 pm
That is "the other one"
Post Posted: Sat Jun 30, 2012 2:57 pm
What jets did you put in it? You may want to drop back down to a close-to-standard size jet for primary and a bigger for secondary. Otherwise play with the choke and make sure that's adjusted right and working properly.
Post Posted: Sat Jun 30, 2012 3:05 pm
on one of the carbys i have it has 3 screws, and the one under the throttle cable i thought was the choke adjustment one? but in saying that how exactly do u adjust the choke?
the one that i have on the car now only has 2 screws..
Post Posted: Sat Jun 30, 2012 3:21 pm
Sorry I wouldn't know as mine has a manual choke.
Post Posted: Sun Jul 01, 2012 6:50 pm
ok, got it all together and so on now i have a ferral flat spot when i try to take off, im thinking it maybe not getting enough fuel which i can fix by putting an electric fuel pump on which i was going to do anyway???
Users browsing this forum: No registered users and 28 guests
