It is currently Sun Sep 20, 2026 2:58 am
Post Posted: Sun Jul 08, 2012 7:23 pm
What size socket is needed to loosen the front wheeling bearing locknut on a WT front diff?
H
Vehicle: 1985 Holden Drover
Post Posted: Sun Jul 08, 2012 7:49 pm
Sierra?
1989 WT Sierra.
Post Posted: Sun Jul 08, 2012 7:51 pm
50mm deep. But if you don't have one just do what others do and use a hammer and screwdriver.
Post Posted: Sun Jul 08, 2012 7:56 pm
Thanks Bruce.
Post Posted: Sun Jul 08, 2012 8:24 pm
Hammer and chisel if fine to loosen them, but you'll need a socket to put them back together. It's pretty hard to torque up a nut accurately with a hammer and chisel, and accurate torque is critical to bearing life.
Vehicle: Yellow Ute
Post Posted: Sun Jul 08, 2012 8:31 pm
x2 surely someone up there would be nice enough to lend you one
Post Posted: Mon Jul 09, 2012 7:00 pm
You rough prick! 8O
:thefinger:
Post Posted: Mon Jul 09, 2012 7:24 pm
mrw82 wrote:
You rough prick! 8O
:thefinger:
Learnt from you ya rough bastard :thefinger:
Post Posted: Mon Jul 09, 2012 7:27 pm
Never had a bearing fail after being tightened with my torque-chisel
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Wed Jul 11, 2012 10:16 pm
haha torque chisel!!!
If it ain't Broken, You ain't tryin hard enough...
Vehicle: 2018 DMAX
Post Posted: Fri Jul 13, 2012 6:36 pm
I use a 55mm toyota (hilux maybe?) hub socket if you can't find a 50mm cheap enough. My 55mm was $60 less than a 50mm at the locale Bursons..
Post Posted: Sat Jul 14, 2012 10:46 am
Hammer and chisel worked fine to loosen it.
Vehicle: SJ51T
Post Posted: Wed Aug 01, 2012 6:51 pm
do you need to have any gaskets or grease on hand to tighten the bearing's locknut up ?
going to do mine as soon as I get my socket in the mail
Humble beginnings
Post Posted: Wed Aug 01, 2012 7:41 pm
The hilux hub socket is 54mm. They work good, sit on the flat of the socket and you can torque them up proper. If you get caught out mate, I have 2 54mm sockets here and can send you one for about $30.
Dave
Post Posted: Wed Aug 01, 2012 10:12 pm
If your just retorqing them you could get away with none. But i would have some grease to repack your freewheeling hubs while your there.
there is a gasket between your fwh and your hub but i dont really worry about them haha. Just be careful taking the first part of your hub off and youll be fine
I love lamp
Vehicle: SJ51T
Post Posted: Wed Aug 01, 2012 10:14 pm
Thanks Joshyboy26.
P.S. r u part of the vic club ?
Humble beginnings
Post Posted: Wed Aug 01, 2012 10:59 pm
Not yet haha im a bit lazy ive been meaning too sign up for a while but i will very soon
I love lamp
Users browsing this forum: No registered users and 58 guests
