It is currently Thu Sep 24, 2026 8:37 am
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Mon Jul 16, 2012 8:47 pm
Gonna do an oil change and filter with spark plugs tomorrow heres my list what do you GV owners think of it
Moreys oil additive
6x Denso pk20prp11 spark plugs
5.5l full synthetic 10/40 nulon
Ryco Z172 oil filter
Nulon Oil flush
Do those sound good, I've read through others but wondering whats current
2004 GV, Calmini 2.5" + 1in spacers
Post Posted: Tue Jul 17, 2012 1:05 pm
I use a genuine suzuki oil filter and 10/30 oil
Post Posted: Tue Jul 17, 2012 1:16 pm
I wouldn't stick morays in a good motor
Post Posted: Tue Jul 17, 2012 1:56 pm
x2 (for the grade of oil)
I used 10w 30 in my GV as well but used Castrol.
Never had chain rattle.
Vehicle: LJ80
Post Posted: Tue Jul 17, 2012 2:06 pm
i use 5w 40 penrite and a generic filter. change every 5k
and i use kero as an oil system cleaner every 2nd change
Post Posted: Tue Jul 17, 2012 4:19 pm
Why not? What about a different brand like Flashlube?
How much kero do you use?
Any problem with using the 10W/40 Oil over 10W/30??
Post Posted: Wed Jul 18, 2012 12:31 am
Check your manual, you'll see 10w40 recommended over 10w30 in situations where the ambient temperature exceeds 30*C.
Post Posted: Wed Jul 18, 2012 12:45 am
Thats a good thing for using 10w40 over 10w30 esp here in SA where summer is hot. I checked the manual and saw that 10w40 had the best range for me but other than temp ranges whats the benefit of using 10w30 over 10w40?
The recommended temperature range are as follows
10w30: -25Celsius to 38Celsius
10w40: -25Celsius to no limit
In other words the difference between the two oils is the 10w40 has same performance at low temperatures, but works well also above 38C
So why are so many using 10w30? Because they don't need the higher running temps and prefer the thinner oil for less friction??
