It is currently Mon Sep 21, 2026 10:33 am
Post Posted: Sat Jul 21, 2012 5:05 pm
so im planning of shaving my diffs front and rear, my goal for doing this is i dont want to run tyres bigger than 215 75 15 but i still want the ground clearence so im not dragging my diffs around in the ruts. the car will be used for touring, beach use and the occasional off road moderate tracks.
im a bit cautious as this will take away the diff oil volume, and wondering will that effect the diff wear and tear wise?
i appreciate your feedback as im new at doing these type of mods also i will not be the one doing the work.
thanks Doug.
Post Posted: Sat Jul 21, 2012 5:12 pm
Pro: Increased ground clearance.
Con: Less oil volume... No real drama.. Just change the oil a bit more often.
Con: No drain plug.. remove one or two of the bottom bolts to drain oil.
Post Posted: Sat Jul 21, 2012 5:22 pm
Con: A lot of work for not much
Con: Diff can warp with welding
Con: Diff can leak if not done right
Post Posted: Sat Jul 21, 2012 5:29 pm
Con: A lot of work for not much Every bit helps though.
Con: Diff can warp with welding You'd have to put a LOT of heat into it
Con: Diff can leak if not done right True.
Post Posted: Sat Jul 21, 2012 5:37 pm
for example say im driving for 2000k's straight with no oil change will having less oil effect the wear on the car?
how often should i change the diff oil if i do it?
thanks for the feedback
Post Posted: Sat Jul 21, 2012 5:56 pm
It'll be fine.. You are only reducing capacity by 15-20% or so.
What is the recommended service interval?
Increase it by 40% if you are really worried...
EG Every 50,000Km down to 30,000Km
Post Posted: Sat Jul 21, 2012 5:59 pm
thats not to bad, i;d rther be servicing my diffs every 30,000k's anyway.
another question, when shaving the front diff does the front side gear move when driving in 2 wheel drive? just curious.
thanks for your reply
Post Posted: Sat Jul 21, 2012 6:04 pm
shouldnt no.
Post Posted: Sat Jul 21, 2012 6:07 pm
yeah thats what i was thinking. so really its only the rear diff thats getting a workout.
Post Posted: Sat Jul 21, 2012 6:39 pm
indeedy
Vehicle: LJ20 LJ50
Post Posted: Sat Jul 21, 2012 6:45 pm
what are the pros and cons of pumpkin shaving?
WELL SMOOTH SKIN OBVIOUSLY
Camels have nice toes
Post Posted: Sat Jul 21, 2012 8:02 pm
Ive done it on mine i reckon you only lose about 50-100ml or so but i wouldnt worry its really not a lot. Just make sure you have good weld in and outside.i deleted my drain plug but you could easily put one back in. Mine doesnt leak, if your iffy about any weld just grind it out and do it again. Mine is 5mm plate on the bottom and i welded the shit out of it and it didnt warp. All pros no cons!
I love lamp
Post Posted: Sat Jul 21, 2012 9:38 pm
if its for a jimny not sure how much you can shave with the small front housing.
Post Posted: Sat Jul 21, 2012 9:53 pm
got complete front and rear diffs today, including centres.i will be bracing them both and hopefully be shaving them, im tossing up about shaving the front but need to find out where the lowest point is on the diff. only time will tell
Post Posted: Sat Jul 21, 2012 9:58 pm
IMO For the reason of use:
Its not worth it. Extreme tracks where maximum clearance is needed, yeah ok. Might be worth the trouble.
The jimny rear diff is bigger than the front, including the housing. So any shaving you do to the front, the rear will still be lower etc. Bit to think about.
Diff housings, the centres sit on an angle, so work that out, with a centre inside it, and measure away. Remove the centre before cutting :lol:
Post Posted: Sat Jul 21, 2012 10:01 pm
Sounds like you are bored and doing the mod anyway. :lol:
Post Posted: Sat Jul 21, 2012 10:38 pm
i wont be the one who is doing the cutting and welding as i am not experienced enough. im still undecided about shaving the diffs but one thing i do know is i am not planning on selling the car for another 4 to 5 years. so who knows what i will be doing with car, but i do know i dont like doing things twice. if i do it, it just makes my car unique when selling in the future
Post Posted: Sat Jul 21, 2012 11:59 pm
if you consider that taking 12.5mm off the diff is equivalent to going up 1" tyre size as far as clearance is concerned its a pretty worthwhile mod - but only if you find yourself constantly smacking the diff on things (its often quite easy to avoid hitting the diff by choosing an appropriate line) - but for a comp truck its almost a must i would think.
Post Posted: Sun Jul 22, 2012 1:10 pm
Its not really the same as going up in tyre size because that lifts everything, shaving moves about 10 square centimetres of the car up about 2cm. Total waste of time for what you use the car for Dougie.
Users browsing this forum: No registered users and 46 guests
